Serpentine Set-up
I just wanted to see who all is running a Serpentine Belt Set up on they're SBC motor and get some feedback from you guys. likes? dislikes? pro's vs. con's i have the option to pick up one of these set ups realtively cheap so i just wanted to see if it would be worth it. thanks for your help guys.
Re: Serpentine Set-up
i have that setup
i cant tell you how i like it yet because i havent started it up..but its really easy yo put on ![]() |
Ttt
![]() Join Date: Jun 2006
I have that same setup. Truck is not quite finished yet, but I like it much better than most of the more expensive aftermarket kits.
Another nice looking option, if it will work with your heads is the stock setup on a 96-98 C/k truck (vortec motor)
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 |
I will be running a setup out of a 90's camaro. Truck will hopefully be started up later this week...
I have the same set up also. Love mine. Had it on the truck for several years and 32,000 miles and not a problem with it.
Addicted to Chevy
![]() Join Date: Mar 2003
Have the set-up on my 69. The only issue I ran into was the length of the water pump putting the clutch fan REALLY close to the radiator. But since I was installing a Gear Vendor OD and had to redo the driveline anyways I put big block frame stands in which pushed the engine back 1''. And I already had a big block shroud, so it was all good.
Active Member
I have it in my blazer, I love it as well. Got tired of losing belts everytime i redlined.... Sepentine was an obvious step forward in that department.
1969 C10 SWB /350 vortech/th400 1968 SWB build (in progress) 1969 SWB build (my son's future project) 1968 camaro yellow/white stripes (wife's car) 2011 GMC reg cab short bed 2wd daily driver 5/7 drop on 22's 1972 K5 Blazer 13"/11"lift,38"M/T MTZ's, 3" cust exst. 350/350 (sold it ![]() |
chevy truck fan
i have a setup from a '92 sub. & it works great!! i just bolted everything on. the only draw back (if it is one) is that the ac compressor is not a "sanden" type & any vintage air ac setups will require a hose conn. kit, which you can obviously buy from.... vintage air. other then that the system is perfect.
good luck!! |
What did you guys do for the Alt. wires & power steering hoses?
1972 Chevy Blazer 1997 GMC Sierra 2009 Chevy Tahoe |
#13 |
For those of you with the GM serpentine system, how did you finish the brackets? Or are they bare aluminum?
#14 |
I clear coated my alumnium brackets.
#15 |
chevy truck fan
orange72blazer,
i just used a alt clip that i got. i think yo ucan check with some of the vendors on here & tell them what you are looking for & they will be able to get it. alex haley, i just left mine alone for now (cleaned up) , but when i break the truck apart for paint i will probably try to polish them up myself & or have them powdercoated.. |
#16 |
