12-04-2007, 06:06 PM | #1 |
Fuel filler that works, blazer tank?
I built a fuel filler for my blazer tank in my 72 LWB, but I'm not so sure it will work well. I planned on running a coolcap boat style cap in the drivers corner of the bed, with a brass elbow off that and a rubber hose going into the tank inlet. It seems to me that might fill slow and spill over a lot. Is there a better way than that in a LWB? I can't do the sidemarker thing as I have firebird markers. Thanks!
1964 Chevy Short Fleet: Tornado 1972 Chevy C10: Fast Orange Secondaries Wide Open |
12-04-2007, 06:43 PM | #2 |
Retired Air Force Veteran
Re: Fuel filler that works, blazer tank?
What is the diameter of the fill neck on your blazer tank? I have a poly tank and my fill neck is 1 1/4 inch OD. I have a SWB Step Side and I am using the rear marker light on the drivers side.
As for your location, 1st - is your fuel fill line the same size as the cool cap? If, not, how are you going to reduce it? I'm using an S-10 filler neck and it's 1 7/8 inch diameter OD, so I got a piece of 1 1/4 inch exhaust pipe and am going to have it opened to just a tad bigger than the S-10 filler neck size and so it will just slip over, than weld it. The 45 degree filler neck on the blazer tank is a tough angle and 1 1/4 inch makes for slow filling. Do you have a metal or wood floor? If metal, can you use your cap on the floor? The Cool Cap (by Air Ride Technologies I believe) is a real nice cap but you may have to look at other filler caps. I have a wood bed, so I didn't want to screw up the wood with the gas. Thats why I chose the marker. Hope this helps.
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
12-04-2007, 06:45 PM | #3 |
PROJECT 7DEUCE
Try putting the filler behind the drivers side taillight.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
12-04-2007, 06:51 PM | #4 |
As I went into my long winded placement of my filler neck and trying to help Muddpile out, I thought of that and was wondering if there would be any spark with the tail light wires. If that does not pose a problem, for that longbed application - behind the light is a great location.
12-04-2007, 08:03 PM | #5 |
Fat Fendered Fleetside
I put mine in the taillight, seems to be a pretty popular mod now..... I'd suggest that no matter where you decide to put your fill, to make sure to attach a fill vent tube. Without it, the fuel has to go in the same tube the air comes out of, and makes filling the tank slow and sure to have gas dripping/gluging all around the filler. I am using a blazer tank too, but the angled neck does not seem to pose a problem. I used marine fuel filler hose, as the auto supply houses around me didn't have anything long enough. From the blazer fill to the taillight is almost 4'! |M|
71 GMC lwb 56 Big window swb 93 GMC Sonoma (dd) radiused fiberglass fender project for 67-72 |
12-04-2007, 08:43 PM | #6 |
Mordachai, Nice idea. Muddpile, looks like you have some pretty good ideas.
Good Luck
12-04-2007, 10:28 PM | #7 |
I meant to say that I don't think you'd have trouble using that cool cap in the corner as long as it's vented. Before I set my fill up through the light I had the fill coming through the upper surface of the driver's wheel well(they were swiss cheese anyway, another hole didn't make a difference) and it filled just fine.
12-05-2007, 12:08 AM | #8 |
I guess I should explain a little better:
-Poly Blazer tank with 1 1/4" I.D. rubber hose clamped over the filler -Imitation coolcap with 1 1/2" female pipe thread -90 degree brass 1 1/2" street elbow -1 1/2" x 1 1/4" brass bushing -1 1/4" brass male thread x hose barb that has the other end of the hose clamped over it. The tank is vented, so you think the bedfloor should work decent in the corner?
12-05-2007, 09:42 AM | #9 |
I think it would work, the only thing is that the more horizontal the fill tube, the slower it will fill. I definitely noticed it's slower though the taillight than from when I had it on the wheel well. The filler sits about 3" higher than the tank, so it's a pretty horizontal fill.
If you can elevate it, maybe put it through the inner bedside instead of the floor then it should fill much faster.
12-05-2007, 04:23 PM | #10 | |
Why can't you use the sidemarker fill with the firebird light? I am going to be installing them on my truck soon and don't see the problem with mounting them. It will bolt to the gas door itself. What is the problem you are running into. Maybe I'm overlooking something. Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
12-06-2007, 04:12 AM | #11 |
Mine works really well but isn't the fastest filling. I may have a little more clearance between the bed floor and the tank but it sounds like you have done yours pretty much like the way I did.
12-06-2007, 10:06 AM | #12 |
hey Mudder. Is that a wood bed, or an I seeing things? And if it is a wood be, how is it held down?
12-06-2007, 01:44 PM | #13 |
It is a wood bed and it is bolted down with 9" carriage bolts. They were hard to find btw. The bolts drop through that round spacer you see there under the filler tube.
12-06-2007, 02:27 PM | #14 |
the thing that scares me about these hidden behind the light things is that with a very slight tap you've got loose live wires and an open gas filler . seems to me a better chance of explosion from loose wires and gas fumes than with an in the cab tank // just something to think about when moving a tank for alleged safety reasons huh
12-06-2007, 03:34 PM | #15 |
^ Great point, I wondered about it too when I did it, but figured since the old bel airs filled this way, why not try it out. But I also moved mine for more space in the cab, as well as carrying a little more fuel.
12-06-2007, 04:12 PM | #16 | |
Shawn
12-06-2007, 06:51 PM | #17 |
TOTY 2006
I placed my filler in the left rear stake pocket, and I added a vent from the tank up to about 2 inches below the top of my filler that way the air being displaced by the incoming gas could escape without any slowdown in filling. I have no problems filling my tank. Only other change I made was to add a vacumn valve (from a dirtbike gas tank) so as not to get any vacumn in my tank when driving. Pictures of my filler can be found here. http://67-72chevytrucks.com/vboard/s...d.php?t=207027
12-07-2007, 07:10 PM | #18 |
12-07-2007, 11:58 PM | #19 |
jorgensensc, the firebird marker is held in by itself, at least in my application. I cut the screw tabs off the bed, and put the trim on the outside of the truck and the lens on the backside, then put the nuts on. You might be able to rig it, but it's hard to say. Plus the firebird markers are sunk in, so difficult to grab.
Mudder, thanks for the pic, that is pretty much the idea I have as well. John Fabris, Yours is my favorite on this board. I was going to do it that way, but couldn't find one of those caps around here, so I figured I'd go a simpler way. Panteratron, I must have missed that thread, wow! If I were running LED's, that would be killer.
