Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 12-04-2007, 07:43 PM   #1
bigblock79
67 Chevy Stepside
bigblock79's Avatar
454 for sale or trade
ok i finlley went and got it. i went and pick it up sat. and found out the whole story about it. it is a 454 that was a advance auto store. replacement engine. the po went to advance and bought it and took it to a machine shop and had the studs put in it to hold the heads on and bore it 60 over bought a big cam kit that came with springs and timeing set and had it put in it. and he broke it in the wrong way. drove it on the trailer and off the trailer and it was setting ther idleing and it chew up a couple of cam lobes and the shaveing went to the crank. and scared it a little . he pulled the crank back out and the cam and started to fix when i bought it so it needs a crank kit and a cam and lifters and a homic. blancer. i will trade it for a small block that is bulit or sell it for 1200.00
1967 Chevy stepside
1976 BIG DOOLEY 454 turbo 400 4:11
bigblock79 is offline   Reply With Quote
Old 12-04-2007, 07:49 PM   #2
bigblock79
67 Chevy Stepside
bigblock79's Avatar
Re: 454 for sale or trade
more pic
1967 Chevy stepside
Old 12-08-2007, 11:54 AM   #3
Luvlegs
Luvlegs's Avatar
Any chance you got any/all the brackets and pulleys for it? If you do and aren't going to be using them, let me know. Where abouts in NC are you located?
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 12-10-2007, 12:44 AM   #4
bigblock79
67 Chevy Stepside
bigblock79's Avatar
no brackets . jonesville
1967 Chevy stepside
Old 12-10-2007, 11:40 PM   #5
454_72_4X4
454_72_4X4's Avatar
Does the crank, cam, and main bearing caps go with it? What sort of built small block ya lookin for?
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 12-11-2007, 11:07 PM   #6
bigblock79
67 Chevy Stepside
bigblock79's Avatar
the crank goes but is only good for a core. it mightcould turn down. the cam was bad and it got trash. the main caps are there and the rod caps i got. no haomic. blancer. it is all new motor. i got a orig intake, oil pan, valve covers, and all the push rods. i would like a good bulit 350,400 sb. it can be a few years old i don't want a wore out one and not a new one. just a good bulit sb from mild to wild more wilder the better
1967 Chevy stepside
