Old 12-04-2007, 08:18 PM   #1
timzrides
timzrides's Avatar
Steering wheel slop?
I have an 1988. The steering is loose and is not tight. Short of buying one from somebody, can they be repaired with some type of kit. I notice rebuilt ones on ebay go for 150++. Hoping to find a better solution? thanks
timzrides is offline   Reply With Quote
Old 12-04-2007, 11:21 PM   #2
71/454
71/454's Avatar
Re: Steering wheel slop?
You mean the column itself is loose? If it is what I think you mean it is a tilt column and it just seems to slop about. There are some bolts that come loose in the swivel that makes the column tilt. To fix it takes some special tools, a long afternoon, and alot of cursing. If it were me, I would just change the column. A bit more money, but way less work.
1972 Gmc Custom swb intercooled twin turbo 327 10.5-1 and 12 lbs of boost, Nodular iron case super t-10 4 speed with a blowproof bellhousing, 12 bolt eaton posi soon to have moser axles.
1998 Honda CR250 fully ported, case matched, milled head, vortexed carb and revalved suspension but don't forget the woody woodpecker decal kit!
Things I've broken so far:
12 bolt diff
saginaw 4 spd many, many pieces
Aluminum case Super t-10 4 spd
71/454 is offline   Reply With Quote
Old 12-05-2007, 12:21 AM   #3
get me on the road
No Matter What.
get me on the road's Avatar
I think there is 3 bolts that come loose, and they just need to be retightened. We used to run into that problem alot at the shop I worked at in Akron, OH. Those guys would drive with their seats almost fully reclined, and use the steering wheel to pull themselves back up when getting out of the car, which would cause the problem your having. You do need a few special tools, which you could possibly rent from the parts store.
Currently own:
89 Chevy Silverado
Previously Owned:Starting with my first vehicle
86 Mercury Cougar /89 Olds 88 /88 Chevy S-10 /84 Pontiac Firebird(I miss it) /91 Chevy S-10
get me on the road is offline   Reply With Quote
Old 12-05-2007, 03:51 AM   #4
Kevin45
Kevin45's Avatar
Three bolts and possibly the one latge nut in the center. The '89 I had did that about once every two years. I finally put some blue loctite on the nut to prevent it from coming loose. And like GMoTR stated, it from using the wheel to get in and out of the vehicle.
Kevin
'93 Silverado Reg. Cab Shortbox
.060 over 350 Quick and fun!!!
Kevin45 is offline   Reply With Quote
