12-04-2007, 08:36 PM | #1 |
power brake vaccuum line
I just put a disc brake conversion on my truck and power brakes. Is it better to run the vaccuum off the intake or the carb. And have any of you ever had a master cylinder drain the back resevior into the front and over flow the front resevior. This has been a head ache of a project nothing has gone right . Any help is greatly appreciated. Thanks
12-04-2007, 09:22 PM | #2 |
Chevy Truck Addict
Re: power brake vaccuum line
I'm not positive but I would say you should connect to a vacuum source on the intake.
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
12-04-2007, 09:26 PM | #3 |
Manifold vacuum. Carb has little or no vac at idle.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. Last edited by webfoot; 12-04-2007 at 09:27 PM. |
12-04-2007, 09:36 PM | #4 |
When i did mine i took a plug out right behind carb (V8). Also I had more problems converting to disc brakes it was a Pain. But I am done now.
About the resorvoir problem did you bleed the MC before you hooked up the lines. Good Luck Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
12-05-2007, 06:58 AM | #5 |
Thanks for the responses. Husker we bled the master, proportioning valve and the brakes, still pushes out. we thought after the proportioning valve we had it fixed started the truck and it overflowed and the brake pedal went down and didn't come back up. Think now it is headed to the shop so they can get it done.
12-05-2007, 07:15 AM | #6 |
its bad master cylider it is leaking internally
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
12-05-2007, 07:19 AM | #7 |
Watch out for your cornhole !
Fellas, hook your vacuum connection to the carb. That's where the general connected them from the factory. That way you get full manifold vacuum from a nice big port.
12-05-2007, 12:40 PM | #8 |
sufficiently talented fool
The vacuum can be hooked to the large port in the rear of the carb. It is beneath the throttle plate, so it is manifold vacuum. It can also be hooked to the manifold port where the auto trans modulator is hooked by changing the fitting. Either place is acceptable. As far as the master cylinder, replace it if it is transferring fluid between reservoirs.
"it's impossible to be surrounded by idiots when you are part of the circle" 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
12-05-2007, 01:56 PM | #9 |
Son of a gun
They are hooked to the bottom rear of the carb from the factory! but some carb bases do not have the tapped boss on the rear.
Hooking to the manifold will work fine too though.
Bill BEATERS ARE NEATER Last edited by Bus Ted Knuckle; 12-05-2007 at 02:36 PM. |
