Old 12-05-2007, 08:49 AM   #1
Slammed70
Slammed70's Avatar
Other than just being annoying...
Is having a "cupped" tire something to worry about?
ultra rare corvette option package
Slammed70 is offline   Reply With Quote
Old 12-05-2007, 08:53 AM   #2
Re: Other than just being annoying...
Accelorated front end wear.
Old 12-05-2007, 08:54 AM   #3
woodridge
woodridge's Avatar
If the tire developed the "cup" after it was installed on the vehicle, then you have an alignment/suspension issue. Other than noise and reduced tread life, no, there is nothing to be worried about.
SEMA Network- Protect our Hobby!
71 C30 in pieces, starting to come together.
Click here for A Place For Tennessee Truck Enthusiest To Meet
woodridge is offline   Reply With Quote
Old 12-05-2007, 08:54 AM   #4
chris71
chris71's Avatar
good year wranglers?
'55 3100 2nd series short-bed stepside
'70 Corvette coupe stingray
'71 Chevelle 2-dr coupe SS clone
'71 C10 long-bed fleetside
'83 long-haired brunette wife
chris71 is offline   Reply With Quote
Old 12-05-2007, 09:53 AM   #5
68gmsee
Active Member
68gmsee's Avatar
If it's true cupping it may be caused by a bad shock or, as mentioned any suspension component.
If it's minor it's usually not a concern but if it's bad and in the front, it could cause some problems in wet/icy conditions. The main thing is to identify the part that is causing the problem before it gets worse.
http://www.procarcare.com/includes/c...dtirewear.html
68gmsee is offline   Reply With Quote
Old 12-05-2007, 10:10 AM   #6
It happens on 4wds when tiresaren`t rotated even if there are no worn parts.I had a improperly adjusted wheel bearing cause a cupped tire.
Old 12-05-2007, 06:19 PM   #7
Slammed70
Slammed70's Avatar
$400 a pop Lexus approved tires from the dealershi(t).
Old 12-06-2007, 08:54 AM   #8
chris71
chris71's Avatar
lexus tires? suprised me there. i had some wranglers (truck/suv tires) on an suv i had, bad cupping problem, no road noise or other problems, just cupping, i checked with other guys and even looked at complete strangers trucks in parking lots and noticed that alot of wranglers had that problem too, replaced the tires with michellins, got like 20-30 thousand on em and no problems of cupping or anything else. i agree with the other guys here, but i suppose the manufacturer makes a bum tire from now and then, maybe good year had some issues with that particular factory or run of wranglers, maybe there good now but just fyi for you guys out there
Old 12-06-2007, 09:21 AM   #9
truckdude239
truckdude239's Avatar
goodyear wranglers are the worst tires outt here forcupping i worked in thre tire bussiness for 2 years and i replaced many sets of their tire due to cupping
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 12-06-2007, 09:22 AM   #10
Likes others said not a terrible thing, but since you paid that much and thru the dealer I would see if they would replace it, or at leas give you a decent credit for the swap out.
That is too much in my opinion for a bum tire, no matter what brand.
