Old 12-05-2007, 09:01 AM   #1
geoman
lokar wiring
I conducted a search but still cannot find what I am looking for. I have my lokar transmission kickdown installed but I need to run the 12V source. Fro those that have it, what gauge wire did you use and where exactly did you connect it for your source? Fusebox?
Thanks for helping me out!
Mike
1967 Fleetside, Sanford and Son Special
Ivory/Blue Vinyl, 350/TH-400/12-bolt
geoman is offline   Reply With Quote
Old 12-05-2007, 09:26 AM   #2
jkaylor68gmc
jkaylor68gmc's Avatar
Re: lokar wiring
I have the kit from Ron Francis nd I believe they all ork pretty much the same. I simply used one of he slide on connections on the fuse panel to give it twelve volts and grounded mine to the pan.
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 12-05-2007, 09:55 AM   #3
geoman
Re: lokar wiring
thanks jkaylor....the previous owner(s) were a little creative on my under dash harness. I have been trying to work the bugs out and get it looking better.
It has a push button start so I need to reconnect my new ignition switch. Also just to the left of the original fuse box is a "fuse panel" but it doesnt look like anything is hooked up. I guess I will pick a spot and connect the wire to a 12V source and see if it works.
Do you think 12 gauge wire would work? Directions indicate it only needs a 5 amp source.
