Old 12-05-2007, 04:37 PM   #1
Magnuman
Rear Brakes
Has anyone used this compnay to convert the rear to disk brakes on a 4wd?
It shows as 2wd but they make it for a 4wd also.
Are disks in the rear a big improvemet on the 71 Blazer?
http://www.mpbrakes.com:80/products/...product_id=483
Magnuman is offline   Reply With Quote
Old 12-05-2007, 06:01 PM   #2
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Re: Rear Brakes
I know a few of the guys have used Blackbird Customs. I am going to go with them when I do the C10 and the K5. They are about 1/2 that much as well.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 12-05-2007, 06:10 PM   #3
red71cheyenne
Back in the sticks
Re: Rear Brakes
www.blackbirdscustomtrucks.com
Took me a while to find the website.
2011 K1500 Suburban
2014 K1500 Pickup
Old 12-05-2007, 07:20 PM   #4
Magnuman
Re: Rear Brakes
Thanks.
I just ordered the kit from Blackbird.
Old 12-08-2007, 09:02 PM   #5
red71cheyenne
Back in the sticks
Re: Rear Brakes
Post some pics when you get them and after you install!
2011 K1500 Suburban
2014 K1500 Pickup
Old 12-12-2007, 05:38 PM   #6
Green Monster
Green Monster's Avatar
Re: Rear Brakes
Yeah... let us know how they work. Do you need to upgrade your brake booster, master cylinder, or install a manual proportioning valve?
Green Monster is offline   Reply With Quote
Old 12-12-2007, 06:20 PM   #7
Magnuman
Re: Rear Brakes
I had to get a different proportioning valve for the four wheel disc brakes. The part number from CCP is PVKS-4 for the disc/disc valve.
The master cylinder unit in the blazer now is 6772BB2.
The master cylinder needed to be a 1 1/8" bore for disc/disc.
I need to check and make sure I have an 1-1/8" bore.
I have currently disks in the front and drums in the rear.
Old 12-12-2007, 07:48 PM   #8
red71cheyenne
Back in the sticks
Re: Rear Brakes
I tried looking on CPP's website, but it doesn't give you the bore on that master. You'll have to call them I guess to find out if its actually 1-1/8", unless someone has already found that out. Sounds like it's going to be a sweet Mod! Can't wait to see some pics...(hint,hint).
2011 K1500 Suburban
2014 K1500 Pickup
Old 12-13-2007, 01:47 AM   #9
Magnuman
Re: Rear Brakes
You need to tell them the diameter of your booster. As soon as I do that they will let me know what size the the bore is.
Old 12-13-2007, 08:18 AM   #10
Huck
Huck's Avatar
Re: Rear Brakes
In reality, rear disc brakes on blazers or trucks is a ho-hum. If the stock disc/drum's are working correct, they are fine. The 99-2005 went disc/disc with lots of advertising but they went back to rear drum with NO mention in their ads. The emergency brake on rear discs is usually crap. So, they look cool, work ok but don't expect a quantaum leap in brake performance. Now fronts is a different story. Huck
Huck is offline   Reply With Quote
