Old 12-05-2007, 05:22 PM   #1
bigunde
Rusty Rockerfeller
putting 4 wheel drive in a 80 chevy van??
will the front differential and springs froma 73-87 chevy fit a fullsize chevy van?
bigunde is offline   Reply With Quote
Old 12-07-2007, 08:34 PM   #2
Duro5341
Duro5341's Avatar
Re: putting 4 wheel drive in a 80 chevy van??
I don't think so, the earlier vans were a unibody construction so what like the astro's, and safaris
Now the newer savanas are a full frame like the pick-up trucks
Duro
-1986 K10 LWB, 350 HD,TH400
3.08, 30 spline 10 bolt, with an Auburn Posi, 31" tires
All original, second owner truck
-1979 Monte Carlo, 350, 200r4, 3.73 posi
-1987 GT T-top Mustang - slow moving project
Duro5341 is offline   Reply With Quote
Old 12-08-2007, 06:28 AM   #3
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
Duro
Wrong.
Chevy made factory 4x4 vans in the late 70's also.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 12-08-2007, 11:25 AM   #4
Pyrotechnic
Pyrotechnic's Avatar
Wasn't the factory deal a system with 2 front prop shafts and right angle gear drives on each side ? I forget who made the system though.
There seems to be lots of solid axle and leaf spring conversions out there that people do themselves. If you search on google you can probably find these to get ideas.
Pyrotechnic is offline   Reply With Quote
Old 12-08-2007, 05:15 PM   #5
Zoomad75
K5Camper
Zoomad75's Avatar
Quigley. Those guys are the 4wd van experts. GM never made them as a factory build, but company's like Quigley converted many. Unibody vans too. We got a couple of Fed Ex vans in town with a 4wd setup.
There is a guy in the 4x4 forum with one too. It's killer looking too.
http://67-72chevytrucks.com/vboard/s...d.php?t=256358
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 12-08-2007, 06:42 PM   #6
68K20 x Drill
My friend had an 86ish Coast guard surplus van that used all normal 4x4 parts.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 12-08-2007, 10:34 PM   #7
ElGracho
ElGracho's Avatar
I was way off here.
I have seen so many 78ish to 80ish 4x4 GM vans I thought they were factory. I just went back through my literature (GM had 4x4 only brochures in the late 70's) and saw no mention of the vans. The people doing the conversions must have done well distributing them...
I still think the full size vans (at least 73-87) had frames. Am I wrong on that?
Joe
Old 12-08-2007, 11:56 PM   #8
Zoomad75
K5Camper
Zoomad75's Avatar
Until they changed the body style in 97, they were unibodies. The express vans went back to a full frame.
I'm not sure how easy it is to convert but it's been done.
Rob Z.
Old 12-09-2007, 01:11 AM   #9
kevinr1970
Are you sure?
I am pretty sure the full size vans had frames. I don't have anything concrete to prove it but I am like 95% sure.
I am nor sure but wouldn't be surprised if the Astro vans were unibody but am pretty sure the full size vans had full frames.
I think another company that did conversions was called Pathfinder. Or maybe that was the name of the Quigley conversion?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 12-09-2007, 09:13 PM   #10
The Intimidator
The Intimidator's Avatar
Originally Posted by kevinr1970 View Post
Are you sure?
I would have to agree with this one the full size vans had a full frame under them the astro/safari had the half half uniframe going on lol
87 k1500 rcsb
4 inch lift 33/12.50/15 bfg a/t's
soon to be 350/350/205 with a 14bs/f built 10 bolt front and 35" super swampers
The Intimidator is offline   Reply With Quote
Old 12-09-2007, 09:16 PM   #11
bigunde
Rusty Rockerfeller
mine is full frame
Old 12-10-2007, 06:23 AM   #12
GM72K10
Next!
GM72K10's Avatar
Here's a gov surplus 86 4x4 van:
http://cgi.govliquidation.com/auctio...&convertTo=USD
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 12-10-2007, 05:05 PM   #13
Pyrotechnic
They look like they are full frame because the body has 2 supports that are welded to the bottom of the van to make it rigid. It's a unibody design though.
Same with Astro vans. Even being very closely related to the S10, they still used the same unibody setup on it.
Why? I'm guessing because the way the unibody was designed, it was just as strong as a full frame but weighed a little less for better gas mileage. It worked just fine too, seeing as they offered 1 tons as well as the extended vans.
