Old 12-05-2007, 05:52 PM   #1
SactoJim
SactoJim's Avatar
Pinion Seal Question
Rearend was built a few years ago and sat for quite awhile before I drove the truck....think it dried out or something cuz it's leaking.
Need to replace and wanna make sure to do it correctly. Isn't there a set "preload" on that and what's the best way to replace this seal. I've done it once before, but many years back and can't remember the details.
Rearend is a factory 12 bolt posi.
Thanks!
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 12-05-2007, 06:24 PM   #2
Blazer1970
Blazer1970's Avatar
Re: Pinion Seal Question
Modern seals do not "dry out". It is likely that there is a groove worn into the seal surface of the yoke, and you will not be able to make a new seal work without addressing that issue. A new yoke or a repair sleeve will fix it right up.
Blazer1970 is offline   Reply With Quote
Old 12-05-2007, 07:12 PM   #3
SactoJim
SactoJim's Avatar
Seems kinda odd that would be the case since after I had it rebuilt, I put fluid in it and it sat for a couple years (It was rotated manually many times) and didn't start leaking until I got the truck running and started to drive it around a little.
does the bolt that holds the yoke on have to go back in the exact same position after I replace the seal?
- supercharged 383
- 4 wheel discs
My Build Thread
Old 12-05-2007, 07:27 PM   #4
68gmsee
Active Member
68gmsee's Avatar
I replaced the seal on my 68 GMC about 3 months ago. I used an impact wrench to remove the nut (only way to go...) and don't remember any issues with the project. Should be fairly straight forward- pry the old one out and tap the new one in with a large socket or similar object.
I used the impact wrench to retorque it. Went pretty smooth.
68gmsee is offline   Reply With Quote
