12-05-2007, 07:37 PM | #1 |
72 tilt wheel
Does this column and wheel look factory to you guys, I took it out of a 72 blazer, ThanksAttachment 319382
Attachment 319383 Last edited by otsenre; 04-05-2008 at 09:57 AM. |
12-05-2007, 07:47 PM | #2 |
Problem Child
Re: 72 tilt wheel
The wheel looks like a van wheel.I cant tell on the column
1972 gmc sierra grande 350/350 a/c soon`to get a new 350 I Survived Norwood |
12-05-2007, 07:48 PM | #3 |
Re: 72 tilt wheel
Can't tell without seeing the lower end and the column itself. How far does the shaft stick out of the end?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
12-05-2007, 08:04 PM | #4 |
Re: 72 tilt wheel
I will take better pics of column tommorrow, Thanks
12-05-2007, 08:38 PM | #5 |
Self-proclaimed LED man
Re: 72 tilt wheel
Is the electrical wiring connector flat or U shaped? Cant tell from the pics. If its a later van column it will be flat. The factory tilts will be u shaped This is one way to tell, unless its all cut up which is what appears to be the case.
My LED Website My Photobucket Album of LED's Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK I also do LED: -Third Brake/Cargo -Brake (truck and burb) -Reverse (truck and burb) -67-68 Front Turn Signals -69-70 Front Turn Signals -71-72 Front Turn Signals -GMC Front Turn Signals I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once Norwood Survivor Last edited by 724x4a/cchevy; 12-05-2007 at 08:39 PM. |
12-05-2007, 08:42 PM | #6 |
its all about the +6 inches
Re: 72 tilt wheel
the older van tilts had the same style connector, and the old red 4 way flasher switch. Since this unit has the long shifter arm, it is going to be the real deal, or an old van unit.
The lilt and turn signal levers are correct, but if memory serves, same thing, the old van units were too. (I think) I have no clue what the steering wheel is, it doesn't look like any van I've robbed collumns out of, nor truck obviously... and being that it is so much smaller than the long shifter on there, it didn't come on that column. From the photos taken, it looks like atruck unit, but like mentioned before, we need to see the other end of it to be certian. |
12-05-2007, 08:50 PM | #7 |
Problem Child
Re: 72 tilt wheel
My uncle had a late 80's early 90's chevy work van.That the wheel looked similar
12-05-2007, 09:38 PM | #8 | |
Re: 72 tilt wheel
Attachment 319420 Attachment 319422 Attachment 319423 Last edited by otsenre; 04-05-2008 at 09:57 AM. |
12-05-2007, 09:56 PM | #9 |
Roadtrip!
Re: 72 tilt wheel
I could always use an extra tilt. Let us know how much shipped without the wheel.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
12-05-2007, 09:57 PM | #10 |
Re: 72 tilt wheel
i zoomed in and couldn't quite tell, but I am 99% sure this is the real mc coy here.
The flat connector and flashe button... if the switch has been swapped out in the last 15 years or so, that was what they got straight from the dealer. |
12-05-2007, 10:05 PM | #11 |
Re: 72 tilt wheel
My truck has a U shape connector, how do they make them fit on these flat connectors, without locating and rewiring another connector,
12-05-2007, 10:07 PM | #12 |
Re: 72 tilt wheel
There is an wiring adapter for anywhere from $5-$12 or so connecting the 2.
12-05-2007, 10:24 PM | #13 |
Re: 72 tilt wheel
GM part number for the adaptor;
1894851 |
12-06-2007, 12:07 AM | #14 |
Re: 72 tilt wheel
Anyone have a truck column out of their truck they could measure? Or does anyone have a van column they could measure? We all know the van columns are 2-4 inches longer than the truck columns right? So if we can get a valid measurement from a known column Ernest should be able to measure the one he has and tell one way or the other.
Frank
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub |
12-06-2007, 12:19 AM | #15 |
Re: 72 tilt wheel
I have a non tilt column in my 70 does anyone know for sure if the nontilts are the same length as the truck tilts?
Frank
12-06-2007, 12:34 AM | #16 |
Re: 72 tilt wheel
12-06-2007, 05:32 AM | #17 |
Re: 72 tilt wheel
From your picture, the column appears to be an original truck column since the shaft only sticks out a couple of inches vs the Van tilt shaft which sticks out 5-6". Also, the neutral safety switch is in the right location and there is not a slot in the column where a van switch would have been.
The shift lever has the Van style knob on it but like the wheel and turn signal switch, it could have been changed. Jim
12-06-2007, 06:41 AM | #18 |
Re: 72 tilt wheel
What about the neutral safety location.Was it moved?
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 12-06-2007 at 06:44 AM. |
12-06-2007, 07:17 PM | #19 | |
Re: 72 tilt wheel
Attachment 319633 Attachment 319634 Attachment 319635 Last edited by otsenre; 04-05-2008 at 09:57 AM. |
