Old 12-05-2007, 09:28 PM   #1
old fart
old fart's Avatar
K10 front hub noise
I went to plow my driveway today with my k10. I have a bad noise comming from the passenger side front hub. I had a 72 GMC 4X4 years ago and I am not sure but I seem to remember I needed a special tool to remove the hub. Am I right about this? Can someone post a diagram showing how to remove the hub. Maybe an exploded view. Also a drawing or picture of the tool I need. Thanks everyone for all your help!!
1970 k10
1967 C10 parts truck
old fart is offline   Reply With Quote
Old 12-05-2007, 11:18 PM   #2
roger0080
Re: K10 front hub noise
Check the u-joint up there first.
72 Chev C-10 90% restored (former AZ truck) ...
71 Chev K-20 Cheyenne my vacation crusier...
72 Chev C-10 Now retired and striped after many faithful miles...
72 GMC 1500 Retired to the junk yard after bought new in '71...
roger0080 is offline   Reply With Quote
Old 12-06-2007, 04:03 AM   #3
Mudder
Mudder's Avatar
You may need some snap ring pliers. There is a large socket for removing one of the retaining nuts in there. Not sure what it is called. It's nearly 3 inches across and has seferal small tabs that lock into the nut.
Could be a bearing is it's that loud.
Mudder is offline   Reply With Quote
Old 12-06-2007, 10:40 AM   #4
old fart
old fart's Avatar
thanks Mudder That is the special tool. I need to find one.
1970 k10
Old 12-13-2007, 09:31 PM   #5
Wreckless_71
Wreckless_71's Avatar
Yeah it's a GM specific castle nut, they're pretty easy to find, and it's easy enough to take that hub apart. Be confident and stay organized.
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project.
1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver.
Wreckless_71 is offline   Reply With Quote
Old 12-14-2007, 02:00 AM   #6
You can use a dull drift punch to drive both spindle nuts off and on.There`s a lock ring between them with a tab that lines up with the grove in the spindle.
Old 12-15-2007, 06:28 AM   #7
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
I've done the drift and hammer method for removing this nut, and it is well worth the money to buy the socket. Napa, checker auto zone all have them available.
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
