Old 12-05-2007, 11:48 PM   #1
skokie
skokie's Avatar
Grant Steering Wheel Install Help
For those who have installed a Grant wheel how do you get the horn part installed? Per the instructions it says to put a piece of tape on the edge of the plastic piece to hold it in piece while finishing the rest of the install. I have done this and it is not working. I know the horn works I put in my old setup and it worked fine.
Help is appreciated.
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 12-06-2007, 06:02 PM   #2
skokie
skokie's Avatar
Re: Grant Steering Wheel Install Help
Ttt
68 build thread
Old 12-06-2007, 10:29 PM   #3
69C10@16
I wish i could help but at least this post will move it up to the top of the forum and then ppl will read it....lol....
69C10@16 is offline   Reply With Quote
Old 12-06-2007, 11:21 PM   #4
matthufham
its been awhile but from the front it goes horn cap, spring, nut, 3 bolts, the ring the horn cap attatches to with the wire attatched, black cover piece, white piece like a straw, spring inside there, then plunger... i think that in which goes through the heavy silver splined piece
matthufham is offline   Reply With Quote
Old 12-07-2007, 06:30 AM   #5
LMN8UR
LMN8UR's Avatar
I re-installed mine a couple weeks ago. Did you buy the mounting kit also? In the kit there is a wire with a button type connector. My instruction said to take the button apart and remove the shaft. Once I did that the internal spring was a pain, so I used a jewelers screwdriver, put the screwdriver through the spring and then managed to get everything assembled.
Good Luck.. ..
72 Chevy C-10 Custom LWB
383 Stroker - Edlebrock Air Gap intake and 670 CFM Holley Street Avenger carb.
Hooker Comp Headers w/ X-Pipe and 2.25 duals
TKO-500 & 3.08:1 rear
I Love HEMI's, they're soft & chewy!
LMN8UR is offline   Reply With Quote
Old 12-07-2007, 07:20 AM   #6
70c10
67-72 Addict!
70c10's Avatar
I remember Longhorn man wrote a FAQ a few years ago. Check in there for it.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 12-07-2007, 08:47 AM   #7
Gray Ghost
Gray Ghost's Avatar
If you bought any other Grant GT than the Mahogany version the horn will probably not work regardless of how you install it. That particular horn setup is a very problematic one. I wound up wiring it to an underdash button after a couple of tries the way they suggest. I've had two of them and neither one worked.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
