Old 12-06-2007, 12:17 AM   #1
dave2953
Dave's not here, man
dave2953's Avatar
Starter Noise
My starter began to make a weird noise yesterday morning when I went out to start the truck. It's making the "click" noise that a starter makes when the battery is dead, but the starter is turning over and will start the truck while the noise is produced. Could this be the solenoid going bad?? Thanks in advance for your help.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 12-06-2007, 06:47 AM   #2
mnunn454
mnunn454's Avatar
Re: Starter Noise
Sounds right to me...Solenoids love to act up in colder weather.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 12-06-2007, 09:53 AM   #3
68gmsee
Active Member
68gmsee's Avatar
Re: Starter Noise
I'm dating myself, but I remember the original Delco solenoids could be taken apart and the copper contact turned around for a "renewed" surface. In other cases it could be sanded and cleaned.
Now they're relatively cheap and I believe, the end cap is riveted.
68gmsee is offline   Reply With Quote
Old 12-06-2007, 10:47 AM   #4
chevguy7
chevguy7's Avatar
Re: Starter Noise
I have had some problems with the connections comming loose on mine in the past when I first bought it. Just had to tighten them back down.
chevguy7 is offline   Reply With Quote
Old 12-06-2007, 12:08 PM   #5
chev74
Addicted to Chevy
chev74's Avatar
Re: Starter Noise
sure its not a bad ground or something of that nature? an arc sure sounds 'clickish'
chev74 is offline   Reply With Quote
Old 12-06-2007, 02:27 PM   #6
OLDIRON69
Re: Starter Noise
Buddy at work had the same issue. It was grounded to the intake whick had oil on it. He went and bought a new starter $200....cleaning the ground wire FREE.
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 12-06-2007, 05:11 PM   #7
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Starter Noise
Sounds like you could spend some time cleaning some of your connections ---to ensure a good circuit when you use the starter. The clicking tells me the solenoid is not getting all of the voltage necessary to make a good connection.
piecesparts is offline   Reply With Quote
Old 12-06-2007, 05:20 PM   #8
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: Starter Noise
I would check this first
LOW DOUGH is offline   Reply With Quote
Old 12-07-2007, 12:30 PM   #9
dave2953
dave2953's Avatar
Re: Starter Noise
I check all of the connections and didn't find anything out of the ordinary. I pulled it and had it bench tested at the parts house and when they ran the test the solenoid was making all kind of racket. They replaced the starter for free and all is well. Thank you all for the suggestions!
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
