Old 12-06-2007, 01:09 AM   #1
truckguy_69
truckguy_69's Avatar
Question fuel filter ?
im going to replace the filter on my truck, and was wondering what brand/type of fuel filter you guys runing on your trucks?
truckguy_69 is offline   Reply With Quote
Old 12-06-2007, 06:57 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: fuel filter ?
I run those cheap Fram inline filters that you can get at Walmart for about 3 bucks. I like to put them in the little section of rubber hose underneath the right rear corner of the cab rather than in the engine compartment.
Old 12-06-2007, 07:25 AM   #3
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Re: fuel filter ?
I put one of those fancy glass filters in the engine compartment and it looks real nice with all of the chrome and nice that you can see how clean or dirty your fuel is BUT location, location, location. I put mine about 6-8 inches South of the fuel rail between the carb and fuel pump and Tx Firefighter (Thanx Tx) quickly noticed it was very close to the valve cover. A BIG FIRE HAZZARD IF IT BREAKS.
I'm Going to change it over to the Fram also, but put it closer to the fuel pump opposed to the fuel rail.
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 12-06-2007, 08:43 AM   #4
truckdude239
truckdude239's Avatar
Re: fuel filter ?
i gbot a plastic see though from advance auto that is an inline 2 pieces 3/8th hose before the carb
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 12-06-2007, 10:10 AM   #5
Ole Blue 68
Ole Blue 68's Avatar
Re: fuel filter ?
Oh boy, have I had a hard time with inline filters. I started off with a cheapo 2 piece glass filter from LMC; pretty much leaked from the start. Then I moved up to a 2 piece all metal Edelbrock filter; that was fine for about 6 months but then started to leak and nothing I did stopped it from leaking. Sooo, now I'm on my 3rd filter; this time it's a one piece plastic filter from NAPA and it's held up so far. I figure I'll just change out the whole filter once a year instead of messing with a two piece version.
Ole Blue 68 is offline   Reply With Quote
Old 12-06-2007, 10:48 AM   #6
chev74
Addicted to Chevy
chev74's Avatar
Re: fuel filter ?
GUYS!!!!!!!!! use a Wix filter. Wix for any kid of filter that comes in contact with fluid basically. Well, i guess that would only be oil and fuel, but WIX is the way to go.
chev74 is offline   Reply With Quote
Old 12-06-2007, 12:16 PM   #7
Tx Firefighter
Re: fuel filter ?
While I agree that Fram sucks, I feel they are plenty sufficient for fuel under these conditions. Three bucks at China Mart is good too.
I also agree that Wix is good.
Old 12-06-2007, 12:26 PM   #8
truckdude239
Re: fuel filter ?
i'm a big fan of puratlor filters
David fuller
2000 Tahoe 5.3l 378
Old 12-06-2007, 03:58 PM   #9
Southedisto
River life......
Southedisto's Avatar
Re: fuel filter ?
I'm a cheapo fram inline guy also.
Southedisto is offline   Reply With Quote
Old 12-07-2007, 08:42 AM   #10
chris71
chris71's Avatar
Re: fuel filter ?
i am a el cheapo filter user myself, i prefer to use the clear ones, so you can see if they get alot of trash in them you can replace them. i like the clear ones because in case of a problem you can easliy diagnose whether or not fuel supply is an issue .With the cheaper ones, its probably a good idea to change them more often, IMHO, i have my filter right under the cab, if there is trash in the gas, this way it wont get into the fuel pump, where if there is a lot of trash may screw up the pump, at least over time, some may say that a filter after the pump is good in case some of the metal parts in the pump get rusty and the rust particles make there way to the carb, i have seen this before. i'll use this opportunity to bring something up, i am a culprit here too, but it is a good idea to stay away from rubber lines between the carb and pump, because when the rubber hoses get old, crack, fuel will spray all over, i have had the ends of rubber hose crack and start to leak fuel at the carb, of which i had replaced that hose like 5 years ago, this is why from the factory, the trucks came with hard lines pump to carb, i know, it is easier to put a filter there and to replace it instead of crawling under the truck. at least check those hoses occasionaly for cracks and pinholes, not trying to scold anyone here, i am guilty too, just dont want to see anyones truck go up in flames
'55 3100 2nd series short-bed stepside
'70 Corvette coupe stingray
'71 Chevelle 2-dr coupe SS clone
'71 C10 long-bed fleetside
'83 long-haired brunette wife
chris71 is offline   Reply With Quote
Old 12-07-2007, 08:51 AM   #11
Tx Firefighter
Re: fuel filter ?
Originally Posted by chris71 View Post
...snip... i'll use this opportunity to bring something up, i am a culprit here too, but it is a good idea to stay away from rubber lines between the carb and pump, because when the rubber hoses get old, crack, fuel will spray all over, i have had the ends of rubber hose crack and start to leak fuel at the carb, of which i had replaced that hose like 5 years ago, this is why from the factory, the trucks came with hard lines pump to carb, i know, it is easier to put a filter there and to replace it instead of crawling under the truck. at least check those hoses occasionaly for cracks and pinholes, not trying to scold anyone here, i am guilty too, just dont want to see anyones truck go up in flames
You speak the truth. Something I'm noticing lately, is that fuel hose now days doesn't last as long as it used to. After a short while, the new stuff gets dry rotted. Twenty years ago, it lasted much longer. I don't know if it's the smog in the air or newer rubber formulations they're using.
Old 12-07-2007, 02:09 PM   #12
wibilly
wibilly's Avatar
Re: fuel filter ?
i'm guessing it's the ethanal in the fuel. i run a see thru at the tank and a paper elemit in my q-jet
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 12-07-2007, 02:30 PM   #13
OrangeCrush1970
OrangeCrush1970's Avatar
Re: fuel filter ?
I run the clear Fram's as well, never had a leak. Im starting to wander if it's in the safest place though. Just about 8" off my Q-Jet and almost over the valve covers. Hmmmm....
Rottenwood Garage
1970...71...72 C1500 aka Orange aka Sideshow Bob
540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600
2 Tons of Fun
OrangeCrush1970 is offline   Reply With Quote
