Old 12-06-2007, 02:14 AM   #1
crawdad
crawdad's Avatar
Radiator Overflow Tanks
I had to order a replacement overflow tank for my truck recently. I got the first one on and found out it leaked. Sent it back and got a replacement and it leaked also. Sent it back for a refund. Both of those tanks leaked in the same place as the original one on my truck which, as far as I can tell, is right down near the bolt hole closest to where the overflow tube connects. Does anyone have a good way to seal up a hole in one of these tanks, or do you know where I can get one that want leak. Thanks.
2012 Silverado LT 1500, 5.3, 6 speed auto
'86 SWB C-10 Silverado
crawdad is offline   Reply With Quote
Old 12-06-2007, 02:54 AM   #2
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Re: Radiator Overflow Tanks
Not really sure how to seal it up. I have a 2 liter right now for an over flow bottle . Mine leaks in the same area your talking about. I think its only a few years for that type of over flow bottle also.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 12-06-2007, 09:59 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Where did you order it from? I got one from LMC and it worked just fine.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-06-2007, 10:28 AM   #4
runrx02
maybe you are tightening the bolt too much?
runrx02 is offline   Reply With Quote
Old 12-06-2007, 11:25 AM   #5
bowtier
Nobody rides free
bowtier's Avatar
I got this stuff called "Seal-All" at the local NAPA. It says it will work on anything including gas tanks. I used it to hold my weatherstripping & it seems like top notch adhesive/sealer.
'71 C10 LWB 400SB/350TH
'86 K2O LWB 350SB/400TH-6" tuff country lift, Shackle flip - plow truck
'06 HHR - wifes wheels
'01 Blazer - daily driver
"It's better to burn out than it is to rust."
-Neil Young
bowtier is offline   Reply With Quote
Old 12-06-2007, 01:05 PM   #6
crawdad
crawdad's Avatar
I'll give LMC a try. Thanks.
Old 12-06-2007, 03:03 PM   #7
swb85
On a budget like Fred Sanford
swb85's Avatar
I picked a new one up from the stealership this summer and it didn't leak at all......guess I got lucky---now there's a change.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 12-06-2007, 03:15 PM   #8
Malo83
Cruzzzn' Vet
Malo83's Avatar
BROTHERS didn't leak.
Malo83 is offline   Reply With Quote
Old 12-06-2007, 03:24 PM   #9
454HO
The overflow tank is thermoplastic, so is an ordinary plastic milk jug. I have used strips cut from a milk jug as 'filler rod' and a solder gun as a 'torch' to weld up holes and repair cracks before. Sounds but it does work.
- Greg
454HO is offline   Reply With Quote
Old 12-06-2007, 05:09 PM   #10
crawdad
crawdad's Avatar
I found the leak on the old tank that was on the truck. It was at the base of the nipple. I found some of that "Seal All" bowtier was talking about (good stuff) and smeared all around it. That's all it took, no more leak. Thanks to you all.
Old 12-06-2007, 05:12 PM   #11
piecesparts
Parts and more parts
piecesparts's Avatar
I pitched my plastic one and installed an aluminum tank from an aftermarket supplier.
piecesparts is offline   Reply With Quote
Old 12-06-2007, 05:21 PM   #12
crawdad
crawdad's Avatar
Do you remember who you got it from?
Old 12-06-2007, 05:33 PM   #13
chev74
Addicted to Chevy
chev74's Avatar
im interested as well, i had the original get brittle and bust on me without knowing and i found a couple small pieces floating around the cap of the radioator whenever i check my antifreeze for the winter months...
chev74 is offline   Reply With Quote
Old 12-06-2007, 06:19 PM   #14
piecesparts
There are many different ones on the market. Look at Stylin Concepts for the ones that fit later model Chevy trucks. I put in the tanks for my windshield washer and radiator overflow that fit into a 88-98 Chevy pickup. They can be bolted right to the side of the fenderwells (Original mounting spots, but new mounting holes) and look real decent. There is also Summit racing, Jegs, Yogi's, and may other off-market suppliers on the web. There are tanks of all sizes. The one that I am going to put in my 68 Chevy C-10 is from "Be Cool" radiators and it is of a decent size.
Old 12-08-2007, 11:42 AM   #15
bowtier
Nobody rides free
bowtier's Avatar
Glad it worked for ya. My door weatherstrip had came loose twice so I wanted to try something different. Worked like a charm, been holding almost a year now.
-Neil Young
