Old 12-06-2007, 11:40 AM   #1
70C10Step
70C10Step's Avatar
Driveshaft ???
I am about to put a 350 with 350 turbo transmission in my 70 Stepside. My truck currently has a 350 and 4spd with the granny gear... What driveshaft do I need when I do this swap. I am hoping there is something I can grab out of the junkyard that will work....
All Toys:
1971 C10 Fleetside - I needed it!
1970 C10 Stepside - Midlife Crisis
1969 C20 3/4 Longbed - Beast!
1966 Mustang Fastback - Daily Fun
1965 Mustang Fastback - Money pit!
70C10Step is offline   Reply With Quote
Old 12-06-2007, 01:02 PM   #2
70short
Re: Driveshaft ???
When I did the swap (4-spd-TH400) I removed my carrier bearing, took measurements and had the local driveline shop build me A one piece. Much better. You are a short step right??
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 12-06-2007, 04:53 PM   #3
70C10Step
70C10Step's Avatar
Re: Driveshaft ???
Thanks for the help and that should work for me!!
All Toys:
Old 12-06-2007, 06:30 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Driveshaft ???
if it is a short step, that's not a bad idea.
Call your driveline shop first, to see what they want you to do to get the correct numbers for them to work with.
