offset
I have a 72 Blazer and want to put mickey thompson classic II's with 33" BFG's, what offset should I get to make it look right. I don't want the tires tucked inside the body. Also, what's the shortest lift I could get away with, and what else would I have to change along with the lift? Thanks from the newbie!
SKINNY TIRES RULE!
Re: offset
Welcome to the board from Seattle. Post some pics of your rig when you get a chance.
Sorry, I don't know the off-set, but someone will. You can run 33's without a lift if you're running skinny tires/wheels and don't plan to do any hard core wheeling. 2" - 4" should be sufficient with some wider, meatier tires.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
#3 | |
Re: offset
A 4" back spacing is about the max, anything more and you'll hit the tie rod ends. Lift with 33's all depends on your expected usage, give us more info to go on so we can provide better answers. Pics are a good thing... Last edited by vtblazer; 12-06-2007 at 06:13 PM. |
Re: offset
An 8 inch wheel with 3 1/2" backspacing works good for 33X12.50s. As far as lift, I have been running 33X12.50 BFG A/Ts on my blazer with stock suspension (no lift) for a few years and they have never rubbed. This is with mostly street and some light off-road use (never really twisted up). 33s will rub on a 4 inch lift if you really twist up the suspension.
Tim |
Re: offset
Thanks for the info guys! I'll post pics as soon as she gets here...she's in transit from SW Missouri to NY as we speak. Only problem is I have 8" of fresh snow
#6 | |
![]() Join Date: Nov 2007
Re: offset
Re: offset
Not exactly sure because the truck is on it's way to my house as we speak. I'd like them to stick out a little past the fender...I like that look. Can you get a different back spacing for the rear rims to push them out further so they are more in line with the fronts?
The LuvShack Garage
Re: offset
Since both the Blazers and the Jimmys have an offset tire footprint (Front width is
wider than rear width) anything bigger than stock on a 8"+ rim will stick out a lil ![]()
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
Re: offset
The sidewall bulge of the front tire is probably about even with the top lip (widest part) of the fender. The rears are tucked in a couple of inches. My Blazer is in storage right now so I can't look at it easily. The tires do not have that "look" like they are sticking out. The wheels are stock 15X8 rallies that came on an '87 Suburban. They have the same offset as the older style truck rallies.
Tim |
#10 | |
Re: offset
Is there any problems with using a 10" rim in the rear and and 8 in the front on a 4wd application? |
Re: offset
Re: offset
blazer 1970, nice looking blazer. what type of soft top is that. it's the nicest style i've seen.
#13 |
The LuvShack Garage
Re: offset
You could run 8's and 10's if you really wanted to, and Yes it's because they are 4wd.
The 2wd's do not share the same footprint, IIRC the offset is to get better traction ![]()
#14 |
Re: offset
It is a Kayline top.
Tim |
