Old 12-06-2007, 08:17 PM   #1
kenm78
Broken Down
kenm78's Avatar
71 Interior Cab Light??
I have a 71 C10 has anyone ever wired a door switch in so that when they open there driver and passenger doors the interior cab light comes on?? If so do you have any direction to get this done or do they make a kit for it?? Any input would be great. Thanks
kenm78
1982 Chevy 4X4
Project truck
“It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt”
kenm78 is offline   Reply With Quote
Old 12-06-2007, 08:37 PM   #2
wibilly
wibilly's Avatar
Re: 71 Interior Cab Light??
my 71 has them. there is power to the light all the time the switch breakes the ground when the door is closed
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 12-06-2007, 08:41 PM   #3
aventur1
aventur1's Avatar
Mine to, although I don't think it would be hard, someone will let you know.
aventur1 is offline   Reply With Quote
Old 12-06-2007, 09:50 PM   #4
MT1972cheyenne
MT1972cheyenne's Avatar
It's really simple. All you need is a simple harness & 2 switches. It was a factory option. I added it to mine. The harness just runs to each door switch, (which you must drill 2 holes in the door jams for), and the other end of the harness plugs in at a dome lamp connection that already exists on the drivers floorboard under the carpet, or floor mat. An EXACT reproduction harness is less than $25. I got mine from REZ Engineering. (406-727-9267)
MT1972cheyenne is offline   Reply With Quote
Old 12-07-2007, 07:05 AM   #5
It wasn`t an option,but came on the optional models.Only base trucks don`t have it.The best thing would be to pull the set-up from a truck with it.Check with one of these members/vendors that part alot of trucks.They`d hook you up real cheap.It`s something that prolly goes to the crusher on most of these trucks.
Old 12-07-2007, 06:09 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Option C80 got you dome light jamb switches starting in 69
It was included in teh CST and cheyenne packages, not sure of the lower trim levels.
