chevy truck fan
well guys i am ready to start working on my gauge cluster & i have a few questions. i am going to run A.M. gauges with a alum. bezel (you know the typical setup) & i have a new dash harness installed. i want to know how you guys have hooked up your gauges?
![]() ![]() any help & explainations, as well as pics, would be very much appreciated!! ![]() thanks!! rodstored-72 ![]() |
Re: aftermarket gauges install ????'s
I wired mine basically stand alone.. The only wires I used out of the factory connector was the turn signal and high beam indocaters... I used the AM senders and ran wires from them to the gauges not using the engine harness.
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
Location: Sunny, Florida, some might call it South Alabama
Really? Can that be done with factory style gauges as well?? Cause I thought the temp. and battery ran through the wiring harness
Just sold my C10...sad day... Looking for a 1972 Blazer to hopefully fill the hole in my heart. |
More Cowbell....
I go to the local stereo shop for cars and grab a male & female harness for newer model GM vehicles and make my own. I have not been able to make any connector that will simply plug onto the factory harness. I will attach pics to give you a visual.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
LOL...damn...so I'm gonna need some help...LOL
Not trying to hijack your thread...I'm just doing the same thing when I get back from the desert
nice approach with the plug... Mine is hard wired... Figured once in if it is coming back out I have much bigger problems..
So pretty..... like diamond rings..... but for men.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
Lol
chevy truck fan
so where do the wires from the conn. go to??? once the wires are conn from the gauges?? i am not a smart elect guy as you can tell. i would be willing to do putter's ideas if i knew what to do with the final connections???
![]() Join Date: Nov 2007
Each needs 3 wires, one for 12v, one for the sending unit, and one ground. Voltage gauge only needs 2 because the 12v wire is the sensing wire.
Then each light for each gauge needs 2 more.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. Last edited by webfoot; 12-07-2007 at 12:18 PM. |
chevy truck fan
has anyone on the board try to use the orig. dash harness for the wire conn.??? i thought that i had seen it before & i think the assy. manual shows what each wire is... any thoughts on that idea???
thanks!! |
#13 |
![]() Join Date: Feb 2001
It's really pretty easy. Follow the directions on the individual guage. Usually one wire goes to the sending unit, ground and a 12v switched. Switched is when you turn your key off the power to the guages goes off. There is a prong on the fuse box that will do that. Ground em all and run the other wire to the sending unit. There is also a prong on your fuse box that will operate the lights. Use a test light to find the wires in the harness for your dimmer light and turn signals. There is a wiring diagram here somewhere that will tell you the color of the wires.
#14 |
Tell you what I'll do, This would probably ruin your perfectly good new harness, so I'll take it off your hands for what you paid, and That way you won't have to worry about the pesky wiring harness. I'm really only trying to help you out here. I've got no personal motives ata ll. Just trying to help you recoup your money.
HaHa!! Shawn
#15 |
I used a test light and male and female spade connectors I just figured out what was what and hooked them up to my gauges i used the stock harness for everything except the watter temp and oil pressure guage which is mechanical I allso wired up led's for my turn signals and high beams.
#16 |
![]() Join Date: Apr 2000
I too used a plug from a stero shop and maid my own harnes. The only way to go.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
#17 |
I went to Radio Shack and bought a male/female 12 pin connector set. I then used a very small allen wrench to take out each pin from the dash harness. I read the wiring diagram and matched up the dash wires and gauge wires and pushed the two connectors together. Mine doesn't look as nicely laid out as the ones above though because I did a rush job on mine.
Smoky02: Since I'm right down the road, let me know if you want some help.
72 C10 lwb fleetside -stock 350/350 combo |
#18 |
chevy truck fan
jorgens.,
i would probably be willing to do that but then you would have to buy my new engine harness as well!! the sucky thing about it is that then i would have to buy a painless kit & then figure out how to do all the other wiring as well!! (lol) thanks for looking out for me though(hhaahhaa) anyways i think that i just might try my hand at 68pos's idea as well. i am really enjoying the feedback that i am getting... please keep the thoughts & completed ideas coming... thanks!! |
#19 |
Well, no matter which route you decide to go, it is not very hard. I am not very good with electrical wiring, but not only did I rewire the gauge panel, I installed a Painless harness. Just keep going back and double check and triple check everything. I even bought various colored wire to try to match up with harness and added my own black/white stripes as needed. Like I said, it's not very hard.
#20 |
chevy truck fan
i keep hearing that but for some reason i guess untill i get all the peices & start looking at them i am really nurvous about the task.... it seem as though if it cant be to hard i always seem to find away to make it hard!! (lol)
thanks!! |
#21 |
Hey, are those speedos electric? I never thought about the speedo cable. If so, how do you convert it?
#22 |
#23 |
You have to special order one. I don't remember the company but it is listed on the autometer website. I've got one in my chevelle for the gauge panel I installed. Mine was around $60.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
#24 |
they do make a mechanical speedo too... thats what I have in mine...
#25 |
chevy truck fan
i wonder if you could take the conn. part at the dash (circuit board) and "soder" on wires so you could use the factory connection??? i guess if you have enough talent, tools & patience (unlike me) it could be done huh????
i too am interested in knowing how to hook up elec. speedo??? |
