12-07-2007, 02:47 PM | #1 |
wheres a good place to put a gas tank
i was wondering where is a good place to put a gas tank i have the factory saddle tank im gonna keep it where it is where can i put another one its a k20 72 cheynne long bed
12-07-2007, 03:22 PM | #2 |
Re: wheres a good place to put a gas tank
Before deciding on a location for the tank on a 69 build, I searched for gas tank move and location. I found many pictures already posted that helped make my decision.
Have you slain any this season. I have to stay close to my wife this season due to health reasons, so I have not seen any legal to slay so far this year. We now are limited to 13" antler spread minimun, and the does just looked to small. My son hunted my spot this year and has tagged out. Last one I killed was with the 69 beater farm truck I drive locally. |
12-07-2007, 05:23 PM | #3 | |
Mine is a 2 liter bottle with the top cut off, I built a special bracket to hold it on the header and real tight up against the block. I used some left over plastic tubing from my oil pressure guage for fuel line. And its all just gravity feeding into the top of the carb. I havent had a chance to fire up the engine with the new setup yet, but I dont foresee any problems....
12-07-2007, 05:32 PM | #4 |
Happiness is towing your "new" truck home. 1972 C-10 1982 GMC (parts truck??) 1969 c10 parts truck 1969 C-10 ( my sons) 1992 Silverado 4X4 (now the boys truck)(now mine again) 2002 Tarus (my wife loves that car) |
12-07-2007, 05:35 PM | #5 |
under the bed!
12-07-2007, 05:41 PM | #6 |
its all about the +6 inches
in the cab
12-07-2007, 05:47 PM | #7 |
12-07-2007, 07:55 PM | #8 |
Any other place but the outside of the frame rails like the '73-'87 GM trucks. I wonder if GM learned its lesson? Maybe the tank in the cab wasn't such a terrible place afterall...
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
12-07-2007, 09:21 PM | #9 |
In the cab.It`s a great design that leaves a place for the spare tire under the bed.It takes no effort and doesn`t leave you asking,"where`s a good place for my spare?"Holds 22 gallons,too.
12-07-2007, 09:28 PM | #10 | |
is it sticking out of the hood? i would do that and conceal it inside an 80's style snorkel hoodscoop to get a full "gravity feed" effect |
12-08-2007, 12:37 PM | #11 |
Project underway - finally.
I have been wrestling with this same thing. I want storage room behind the seat, and I want a real spare. What was so wrong with the 73-87 cylinder hanging outside the rails? I had one and liked it there. I was thinking maybe in an accident it could rupture, but I would (in this case) build a cage around it or something. There isn't a really good place for one. I sure as hell am not giving up the bed, although that's another option for the OP.
-Brian
1972 GMC Pre-resto... awaiting allocated funding. |
12-08-2007, 03:05 PM | #12 |
They run up under the cab.The cab floors are raised under the seat to fit the tank.How about the dual aftermarket auxilary tanks?
12-08-2007, 03:41 PM | #13 |
I haven't seen too many of those available. How much are they typically? Are they connected or do you have to fill two?
I was thinking about buying two little cylindrical plastic ones from speedway motors and connecting them like that so you only had to fill one. They are like $40 a piece. Apologies to the OP if I am hijacking but I hope this helps him too. -Brian
12-08-2007, 07:39 PM | #15 |
My truck came with a rear frame tank but I installed one behind the seat!
12-08-2007, 07:45 PM | #16 |
Is your real name Goodwrench?
12-09-2007, 07:55 AM | #17 |
Fabricate till you "puke"
I never did like 22 gallons of fuel riding in the cab with me! My longhorn has a 16 gallon Jazz fuel cell under the rear of the bed.....IMO, it safer, & adds weight to the rear where its sorely needed to help with traction L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
12-09-2007, 09:33 AM | #18 |
i'd keep it in the cab , in a four wheel drive application . especialy a long box . where you see any off roading , i would hate to think you drag you ass and puncture it . many times ive drug my rear bumper , unless you have a good skid plate , it would be leaking and make a mess on the trail and spoil your day .now on a street driven two wheel drive or even four wheel drive, i have no complaints to move it out back .
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car |
12-09-2007, 12:40 PM | #19 |
i wish someone would build an aluminum bed box that had a built in fuel cell underneath it. if i had the right equipment i would try in myself.
12-09-2007, 01:05 PM | #20 |
i have seen the tool boxes with a fuel tank built in at northern tool and equipment. polished dimond plate aluminum $579
common sense isn't so common anymore |
12-09-2007, 04:42 PM | #21 |
Ask the few hundred families that have lost loved ones in fiery side impact crashes for the last 35 years..
12-09-2007, 04:46 PM | #22 |
I knew about that a little bit but like I said I would build a cage of sorts around it. Is it still a bad idea?
Not trying to argue, I appreciate you worrying about me (sorta) -Brian
12-09-2007, 05:16 PM | #23 | |
Dont get the wrong idea here pal....
12-09-2007, 11:01 PM | #24 |
In the cab after all this is a truck .... right. Even my old 60'Vette has it in the cab.
esll.
Tomorrow is for doing today's stuff. ************************************* This truck has just the right amount of energy for me! Author: Warren Lake .... (member) |
