Old 12-07-2007, 04:19 PM   #1
62ChevyStep
62ChevyStep's Avatar
60-62 X-Frame Rear Shock Relocate
Just finished the complete front end rebuild (upper/lower Arms, all Moog HD problem solver parts, 1 1/4 Swaybar etc.)
The rear still needs some adjustment, the rear shocks are laid back to far after the lowering, and are so stiff the ride is terrible! I will get some pics tonight of the rear setup and post them, hopefully someone here can come up with a better way to mount these shocks.
________________________
62' 3.5/5 drop SWB Fleet, PS, PB-Dsk/Drm,350/700R4
08' Chevrolet Silverado CrewCab
05'Toyota Tacoma Prerunner SR5
62ChevyStep is offline   Reply With Quote
Old 12-12-2007, 06:21 PM   #2
62ChevyStep
Re: 60-62 X-Frame Rear Shock Relocate
Alright here are the pic's (sorry I was late, been slammed at work lately)
as I said the rear shocks are "layed back" to far I think, could I just grind off the welds and move them ahead 2-3" 's? I am finishing the short fleet, but I dont think anything should get in the way.
Old 12-12-2007, 06:24 PM   #3
62ChevyStep
Re: 60-62 X-Frame Rear Shock Relocate (two More)
Last two pic's
Old 12-12-2007, 10:08 PM   #4
SIR
SIR
SIR's Avatar
...nice work sounds like that will solve your problem ,(question) how close is your rear end to the frame looks like it's going to "bottom out" and you really don't to do that and if you need to "notch your frame" this would be the time to do it while you can still get around all of it..just a thought....looks good.
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 12-12-2007, 10:41 PM   #5
62ChevyStep
Thanks Sir! I will measure and find out, I used 5" drop springs, didnt think I needed unless it was 6" or more? Also I dont know anyone who makes a C-notch for a 60-62 with the X frame?
Old 12-12-2007, 10:49 PM   #6
thebox
thebox's Avatar
I have been wondering the same thing I have a 61 that I just dropped with 4" HD springs and 2" blocks and the ride is really stiff. If adjusting the shock angle is the answer hopefully someone knows where to get a shock mount kit.
Really like the work you have done, keep the pics coming.
thebox is offline   Reply With Quote
Old 12-12-2007, 10:59 PM   #7
David Flores
David Flores's Avatar
nice, what size wheels and tires are those?
66 c10 swbfs
My Build.
David Flores is offline   Reply With Quote
Old 12-12-2007, 11:04 PM   #8
62ChevyStep
Thnx Box! Ya I hope so too, these X-frames though stout, do call for some modifications not covered by the 63-66 year frames.
Good to see another person from SD on the board (I was born and raised there - La Mesa/Mt Helix, attended State, and left for the Air Force just after) Now retired and living/working in New Mexico.
Old 12-12-2007, 11:07 PM   #9
62ChevyStep
Thnx, Boyd Coddington Smoothie II's 20x8.5, rear tires 275X45X20
Old 12-13-2007, 02:53 AM   #10
TINKERDUKE
The more upright the shocks are, the stiffer the ride. You might think it feels stiff now but when the bed is put on it will be much softer.
Are you still running torsion bars? If so what swaybar did you use? Steve.
TINKERDUKE is offline   Reply With Quote
Old 12-13-2007, 06:24 AM   #11
63sbssbbw
UCA63
63sbssbbw's Avatar
Looking good 62,like Tinker said ,maybe strap some weight on the back and see how she rides
I'm just getting started on a '61 lwb so i'm watching these '60-'62 threads,doesn't seem to be too much on them.
Keep up the good work(and pics,we love pics)
Thanks T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 12-13-2007, 07:20 AM   #12
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I was just going to say that....The shocks are more efficient (work better) when they are verticle.
They would be less efficient (damp'n less, softer) the way you have them.
I would drop the bed on it first, before you start cutting, and moving the mounts.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 12-13-2007, 10:14 AM   #13
62ChevyStep
thnx guys for the input, ya Chief, I think waiting until the bed is ready and test fit, prior to any shock mount adjustments would be wise (measure/ponder multiple times, cut/grind and weld, once)
The truck will stay like this for a while (thus the rear lights and lic plate setup), I still have the Stainless rear gas tank to fit/mount, disk brake kit for the rear, a 21mm (Iroc Z28) rear swaybar to mount, and looks like a C-notch is in the near future. Might as well get all this done prior to the bed going on.
As for the front (Tinker) I am not running the stock suspension (torsion bars), I replaced it with a 86' C10 front end off a donor truck, with 2 1/2" drop spindles and 1" drop springs. the sway bar was off a mid eighties 3/4 ton, 1 1/4" bar, and has made an incrediblely HUGE difference since the complete finished frontend upgrade, drives and handles like a "slot" car, I can't wait to feel it once the rear sway bar is in, reminds me of the stadium drags/slalom races on the weekend at Jack Murphey stadium in SD. I use to race my lowered 65' bug there in the late 70's!
