Old 12-07-2007, 04:32 PM   #1
bios
bios's Avatar
Vibration
I have a vibration in my 79' when I get up to speed on the highway, it's not the wheels or tires. (I just got those replaced.) someone told me it could be my cab or bed mounts, anyone have any ideas before I go and start tearing apart my truck to find out?
Was a 72 C20, replaced with a 76 K5 Blazer.....
bios is offline   Reply With Quote
Old 12-07-2007, 04:35 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Vibration
well the first place id look is the driveshaft either a worn u joint or bad carrier bearing.. if it feels more to one wheel then it would be either out of balance or thewheel bearings is your truck 2 or 4 wd
i have a bad cab bushing and it causes no vibration
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-07-2007, 04:36 PM   #3
bios
bios's Avatar
Re: Vibration
It's a 2wd.
Old 12-07-2007, 04:50 PM   #4
old Rusty C10
Re: Vibration
yeah if it feels like the center of the truck check the carrier bearing and the u joints for play
Bob
I hate cancer!!
Old 12-07-2007, 04:52 PM   #5
bios
bios's Avatar
Re: Vibration
Alright, thank you.
Old 12-07-2007, 05:41 PM   #6
77-383 Step
Re: Vibration
If you just got your tires replaced, it could be balanced wrong or might have thrown a weight?
77-383 Step is offline   Reply With Quote
Old 12-07-2007, 07:18 PM   #7
bios
bios's Avatar
Re: Vibration
I've had my weights be off before and it doesn't feel like this.
Old 12-07-2007, 09:58 PM   #8
xtreme80
Wishin' I had more money!
xtreme80's Avatar
Re: Vibration
Try swapping front tires and see if the vibration moves with it. You may have a bad tire from the factory. I work as a tire tech and about 1 in every 60 or 70 tires turns out to be a bad one, out of round, etc. More so in truck tires than car tires.
xtreme80 is offline   Reply With Quote
Old 12-07-2007, 10:00 PM   #9
bios
bios's Avatar
Re: Vibration
I've actually alraedy tried that and the problem still persists. Maybe I need to be more clear its not a slight vibration the cab will rattle your fillings out..... well maybe I'm stretching a little bit but you get the idea.
Old 12-07-2007, 10:52 PM   #10
old Rusty C10
Re: Vibration
just in case you missed it the first time... driveshaft, u joints, or carrier bearing...make sure the mounts on the motor/transmission are good too, although im positive its one of the others i mentioned
Bob
I hate cancer!!
Old 12-08-2007, 12:59 AM   #11
bios
bios's Avatar
Re: Vibration
Thank you for being so bold, I was just telling them that my tires have nothing to do with it. I will check everything that you recommended tomorrow. =)
Old 12-08-2007, 02:40 AM   #12
xtreme80
xtreme80's Avatar
Re: Vibration
hahahaha... that's awesome
Old 12-08-2007, 03:35 AM   #13
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: Vibration
What's everybody yelling about
Malo83 is offline   Reply With Quote
Old 12-08-2007, 05:43 AM   #14
wolfewerx
Re: Vibration
Finally- some type I can read!!!!
Check those driveshafts before one comes loose and hits you over the head!LOL
wolfewerx is offline   Reply With Quote
Old 12-08-2007, 01:55 PM   #15
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Re: Vibration
Pole Vault?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 12-08-2007, 05:05 PM   #16
Pyrotechnic
Pyrotechnic's Avatar
Re: Vibration
A worn out or improperly set up rear end will vibrate.
An unbalanced driveshaft or worn out U joints will vibrate.
An engine with balance issues will vibrate.
On my 78 I had a worn out improperly set up rear end and an engine with some weird vibrations. Had the rear end rebuilt and eventually replaced the motor and all was good.
Pyrotechnic is offline   Reply With Quote
Old 12-09-2007, 12:20 AM   #17
f.monroe
f.monroe's Avatar
Re: Vibration
My cousin had a vibration after an engine swap . Bent fan blade that vibrated like crazy at highway speeds . Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
