Just a little cleaning makes a HUGE difference
Amassing parts for an interior change...
first pic - starting point second pic - panels after soap and water but before oxyclean.... third pic - visor and one belt... me likkeee I take it, it's normal that all the parchement belts and visors, clips, etc are more like a light yellow but the door panels are closer to white?
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
its all about the +6 inches
Re: Just a little cleaning makes a HUGE difference
try to find some cleaner by the name of Spray 9 and scrub your panels with it. You'll be amazed. I've been spraying that stuff since the early 90's and honestly, it still surprises me from time to time.
It's amazing what a little soap and elbow grease will do. Chris
Soap and water is probably the most under rated of all. I've been using the marine spray nine for the past 12 years on everything - the kids wouldn't even walk by me! Need to pick up some for the house - it's too far to go to the boat to get what's there.
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! Last edited by Luvlegs; 12-07-2007 at 09:12 PM. |
Still no opinions on the yellow vs white'ish issue?
Tot Roddin'
That turned out great!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
All my parchment parts are slightly different in white when you get them out of the truck. When you get them inside, you can't tell the difference. That cleaning sure helped yours like it did mine.
1964 Chevy Short Fleet: Tornado 1972 Chevy C10: Fast Orange Secondaries Wide Open |
Got most of the belts finished last night - once they dried, they look killer! They have a few rust stains and ink spots - they've faded but I still have to figure out how to get them out the rest of the way... or not worry because that parts under the seat..... ahahha
Looks great there! Parchment and white panels are so hard tokeep clean but looks like the oxyclean worked great on them!
1967 Fleetside, Sanford and Son Special Ivory/Blue Vinyl, 350/TH-400/12-bolt |
Actually, the pic of the door panels is after soap and water and BEFORE the oxyclean - the last visor/belt pic is how those came out though after the oxy.
