Old 12-07-2007, 05:53 PM   #1
bad6772
Official Site Guitar Shredder
bad6772's Avatar
Question another trans question
got a few more quick ones....a buddy of mine at work has an 82 chevrolet silverado.lwb...that he is stripping down..it is all stock and never been touched...other than the engine....its a 355 with the factory 4 speed..(it is a NO granny 4 speed.( i also measured his trans at 21 inches mine now is about 17)...any ways i have been having lots of trouble. with finding the correct 3 speed for my 67...its a 250 3speed on the floor.... i know there have been some trans threads but i didnt know if the later model stuff will work(i know it will bolt up but?... i am thinking of running the 82 four speed trans,shifter..everything from it...behind my 250... can i use his drive shaft? if not thats ok....(i can have it sent out to be cut down)...also do i have to run a trans crossmember? basically i can have anything i want of the truck..... but i am buying the engine and trans really cheap....any help would be awsome............thanks tony......
bad6772 is offline   Reply With Quote
Old 12-07-2007, 06:33 PM   #2
1969k10stepside
Re: another trans question
Don't know but I maybe can help you with finding the right 3spd if you want to go that route.
1969k10stepside is offline   Reply With Quote
Old 12-07-2007, 07:26 PM   #3
bad6772
bad6772's Avatar
yeah i might want to go that route?i have baught two 3speed trannies so far..both wrong....they measure 21 inches ....and i need one 17.......
Old 12-07-2007, 07:27 PM   #4
1969k10stepside
I've got access to one from a '64 Chevy..If I can get under it I'll see if it'll work...4 speeds (Not the granny first gear type!) are fun in these trucks..Leave the granny low 4spds to the 4wds or the 3/4 or one tons though!
Old 12-07-2007, 07:34 PM   #5
bad6772
bad6772's Avatar
cool to leave mine as a close to original set up it should measure 17 inches.....to keep from cutting my drive shaft.....i am going to buy the 355/4speed and whatever else i might need..... i can get it all for a 100 dollars....so i think its money well spent.....i would just like to use the 82 setup.....i have four trans now...two 3speeds and 2 four speeds....but i dont have the correct bellhousing...from what i have been told..........
Old 12-07-2007, 08:33 PM   #6
wibilly
wibilly's Avatar
is that 82 trans a overdrive with a hydralic cluch?i think that if it is anything other than a granny 4speed you will have to remove your crossmember and use one from an automatic trans truck. i may have the 3speed you need in a 67 that i plan on putting a 4 speed in
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 12-08-2007, 05:35 AM   #7
bad6772
bad6772's Avatar
i will ask today if its hydro or not.....yeah i would rather have my original style trans.....but having problems finding one....as of now my truck doesnt hae or didnt come with a trans crossmember? was told mine is all original and i believe it to be......headed to work...thanks tony
Old 12-08-2007, 05:20 PM   #8
bad6772
bad6772's Avatar
checked out the trans today....its a non hydro so this set up will work??? also to add this is a non granny 4 speed....it also measures 21 inches...and it looks real close to the 2 3speeds i have already baught....other than the obvious..i basically want to run the 4 speed, the 4 speed bellhousing..shifter..and drive shaft......?
Old 12-11-2007, 04:26 PM   #9
bad6772
bad6772's Avatar
well it looks as if my 4speed deal is falling through free turned into alot more so lol forget it.....my step dad just found a 67 three speed....from what i have seen gm made three differnt style 3speeds in these truck. i don t have pictures to proove yet, but i will... i have looked at 4 different 67s and 3 had the same trans and one had one that is a cross between mine and the ones i have ..<it bolts the same as mine as far as two bolts going into the bellhousing and two into the trans....the one my step dad braught me ,i think will work...im just going to have my driveshaft cut or find the needed driveshaft....the input shafts seem the same.....its wearing me thin.. but it has been a great learning experiance, and hell thats been worth it....thanks for all the help and any more help you can give would be awsome..thanks ..........tony
Old 12-11-2007, 04:30 PM   #10
Devil Pup
Devil Pup's Avatar
Are you lookin for a four speed tranny with the granny gear?
Lifted 2wd 1969 C20/ 5.3LS/4L60E :http://67-72chevytrucks.com/vboard/s...d.php?t=728388
Devil Pup is offline   Reply With Quote
Old 12-11-2007, 06:14 PM   #11
bad6772
bad6772's Avatar
nah i got two of those and one 4 speed with out....i was looking to find my original set up. but i have looked at ,at least 10 trucks with three speeds and all where different than mine....i even looked at some pre 67.s and a few early 60s... mine is weird it only measures 18 inches long while others i have seen are about 21/7/8s so????i just got a 3speed from a 67 swb. that is very close to mine ,but i will have have my driveshaft cut down...or find the right one....i dont know the length yet...that i will need when i switch to the 21/7/8s trans?????
