Foolish Mortal
to lower or not to lower...
Hey guys-the 69 is back from the mechanic (after being gone for 2 months) and I'm happy as a clam working on all the "little" things to bring joy to my DD, however, I got a question for you all...
I have 15" rims on the truck now, which makes the truck look...well....dumb. I'm trying to figure out if I should lower the truck a little to not make it look so high or get bigger rims/tires..... What do you all think? |
Re: to lower or not to lower...
What type of look are you trying to achieve? Do you plan on going with bigger rims? I personally like the look of our trucks lowered so I say lower it. You don't have to go too extreme, go with what you're comfortable with.
72 C10 lwb fleetside -stock 350/350 combo |
Big Block
Drop it!
Between Trucks...
Beat it to fit, Paint it to match... ![]() |
Everything looks better lowered.
nice truck,
go 4/6 and you won't have to C-notch the frame etc... all bolt on/replacement parts; basically spindles/discs (if you have front drums) & springs. You'll still have a nice comfortable ride but will be limited in cargo weight unless you go with airbags in the rear (much more $$$ than a set of springs). my two cents anyway... |
![]() Join Date: Oct 2005
Lower it.......or put some big ole balloon tires on it to fill up that "tire to fender" gap!
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
Official Site Guitar Shredder
i like a moderate drop 21/2spindles with 4"rear coils big and little tires to get the hotrod type look and it actually improves the way the truck looks and handles a lot better to if you include the front and rear sway bars
RIP BigDaddyDave ~7-23-09~ You will be missed~
That is a sweet ride dude! I like the 15" wheels and tires, and yes, it would look even better lowered some.
BigDaddyDave's Truck: http://www.flickr.com/photos/daves71chevy/ | See it in Action! |
lower it
#12 | |
Old Skool Club
![]() Join Date: Jun 2001
![]() This is exactly what I have. Ride and drive is great! I did a little photoshopping and did away with some of the side trim/handles, etc. It's not what it has, but the truck has a 2.5/4.0 drop and is riding on 245-60's up front and 275-60's in the rear, all on Wheel Vintiques 15-inch rallye wheels. Front are 8-inches wide, while rears are 10-inches wide.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. Last edited by ChevLoRay; 12-07-2007 at 08:12 PM. |
#13 |
SLOW BUT SURE,BUT CLOSER
Cliffs right on the drop, moderate and not to costly. And the right look!!
69 C-10, OWNED 35YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS....... ![]() ![]() ![]() |
#14 | |
laying low
![]() Join Date: Mar 2001
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#15 |
lower it and score some 6 lug rally wheels and some 60 series tires to replace the wagons -- or shoot the moon and get some 18's and o-ring tires (i'd do the rallyes if i was on a budget, as you can find sets for 100-200 bucks and 15" tires are cheap, if i wanted to spend more , i'd follow the herd and get some 18" 6 lug Torq Thrust ST's with 245/55 tires)
but its your truck you decide Last edited by streetstar; 12-07-2007 at 09:12 PM. |
#16 |
dave
lower it AND get bigger wheels
check out my build "DIRTY BURB" ![]() |
#17 |
DROP IT! i lowered my 71 short box 4/6 using a kit i got from brothers trucks it came with shocks,springs and front and rear sway bars. not only did it give my truck one hell of an attitude adjustment the truck handles awsome! the whole job took about 4 hours but we did have a lift and a good welder to mount the sway bars.
#18 |
Here ya go....pick one.
My guess is most prefer the second pic.
#19 |
Tot Roddin'
Get that thing in the weeds!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#20 |
Like a Rock!
Lower it!
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! ![]() |
#21 |
It's not the 15" wheels that look "dumb", it's the too small tires. Those tires sure seem little for those wheel wells.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
#22 |
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
#23 |
#24 |
my truck used to look all jacked up too i put some tall tires on it to fill the wheel wells and it looks much better. i have never cared for the looks of lowered trucks[mostly for lose of function] but i can't argue these trucks look awsome dropped. mine will be droped probaly 2/4 when she gets her turn in my shop
common sense isn't so common anymore |
#25 |
Alright Alright Alright
i say keep the 15s and slap on a set of 275/60/15 tires. it worked for me.
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
