Old 12-08-2007, 10:28 AM   #1
larryboz
Need belt size now smog pump is removed
86 3/4ton heavy duty 454. My smog pump finally went and I am removing it and not replacing it but was kind of curious does anyone know what belt part number I would get now that it is gone. I guess I could just measure it but it is snowing here and the truck is outside.
Larry
Larry
1986 3/4 Chevy Truck 454
2005 Z71 Tahoe
2002 Pontiac Trans Am WS6
larryboz is offline   Reply With Quote
Old 12-09-2007, 08:06 PM   #2
OJOE
Crew Cut
OJOE's Avatar
Re: Need belt size now smog pump is removed
Larry
just go to any parts store and tell them you need a belt for your truck without smog pump
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 12-10-2007, 05:14 AM   #3
72freak
Rottenwood Garage Member
72freak's Avatar
With the many years of trying to deal with the McDonalds drop outs that have upgraded to the parts stores......the above might seem like the correct way to go but to be safe and to keep from making 2 trips or 3 trips or 4 trips.............
Take a string and run it in place of where the belt would be. Mark it and check it against the belt they give you..
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 12-10-2007, 01:42 PM   #4
67Cowboy
"GOD BLESS AMERICA !!!"
67Cowboy's Avatar
Exclamation Re: Need belt size now smog pump is removed
The string is a good Idea but an old belt even a broken one works best. Put it around the pulleys and mark or cut it to fit as if you could glue the ends together and it would work. This way you can take it to the parts store and they can put it in their belt gauge that will tell them exactly what the measurement is on the belt you need. It's a devise that looks a lot like one of those things that measures your foot at the shoe store except it has half a pulley on each end and the ruler in the middle gives the overall length. We use to get a lot of farmers, Hot Rod guys, and Industrial machine business and when there are no numbers on a belt and you don't have a book or data to put in the computer, that gauge is worth it's weight in gold.
67Cowboy is offline   Reply With Quote
Old 12-11-2007, 06:01 PM   #5
OJOE
Crew Cut
OJOE's Avatar
sorry ?
85 CHEV SWB/TPI
30 MODEL A HOT ROD
09 STREET GLIDE
Old 12-11-2007, 10:20 PM   #6
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Is your truck a serpentine belt system or a multi belt system?
Do you have a/c or not?
Let me know and I'll get the proper part numbers for you
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
