![]() Join Date: Oct 2006
small block where a 6 cyl was?
Do I need to use the v8 sbc mounts to put a 327 in a '68 that had a 6cyl in it,or will the 6cyl mounts work? I am talking about the frame engine towers. Thank You
-Lance
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
Location: Sunny, Florida, some might call it South Alabama
Re: small block where a 6 cyl was?
you will need small block mounts...there are usually alot of them available here on this site.
Just sold my C10...sad day... Looking for a 1972 Blazer to hopefully fill the hole in my heart. |
Rolled on Paint Club
![]() Join Date: Jan 2006
The I6 towers will work, but it will move the motor way back to the firewall. You distributor will barely miss the firewall tunnel and a belt driven fan will need spacers to reach the shroud for proper cooling.
Bob
1970 GMC 1500 swb fleetside SB 355ci. Smog heads Summit 1102 cam Performer intake and carb. Finally in about 1 piece in the yard. |
huh ???
I've seen many trucks using the 6 cylinder mounts with a V8. Like Bob said though, the motor will be close to the firewall...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
I have my v-8 in the 6 cyl position, when i did the swap I dident know there was a difference. The distributor is close but clears and the back header bolts are kinda a pain to get to. But if you keep it in the 6 cyl position you dont have to get a longer driveshaft and theoretically should help with handeling but with a truck im not shur you could tell.
Thank you very much. I have the small block and 6cyl mounts but the manual trans is bolted to the crossmember via the bellhousing. So it looks like I will be using the 6cyl mounts.
-Lance
Hum.. so by moving the engine back...I'm thinking this help would benefit with both handling and the transfer of weight to the rear. I could see this being a real benefit to these nose heavy trucks and is actually a good idea.
Anyone know how much it moves the engine?
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 Last edited by whatnow123; 12-08-2007 at 06:45 PM. |
#8 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
