Steering column help
Was looking over somethings on the truck before I get a chance to tear it apart and noticed the steering column has a lot of movement in and out. Looked out in the engine bay and there is no support from the bearing and retainer. How difficult are they to change? would much rather spend 35-40 bucks then buy a new column.
Thanks, Russ
71 LWB c10- needs more work than I have money! ![]() ASE certified Ford Master Tech |
Re: Steering column help
If you can work on Fords this ought to be a tinker toy. If it,s not a tilt they are pretty easy to build. If it isn,t a column shift it,s easier yet.
Its a non tilt, column shift. didn't look too hard, just wanted to make sure there wasn't something else hidden or any tricks or anything.
71 LWB c10- needs more work than I have money! ![]() ASE certified Ford Master Tech Last edited by fastazhell; 12-08-2007 at 07:22 PM. |
