Senoir Member
Which Security system to use??
Anybody installed a alarm system in our 67-72 trucks? I'm interested in one, but don't want to cut anything or make a bunch of holes. And, I don't know about brands or types of alarms either. Any thoughts? Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4" 70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010 70 GMC Restoration Pictures http://67-72chevytrucks.com/gallery/...00&ppuser=4424 |
Re: Which Security system to use??
Interior - Rottweiler (sp?)
Exterior - 2 Rottweilers Yard - Smith and Wesson Perimeter - Remmington (I can't believe I was actually able to post that before anyone else did similiar...!) If they can get past those 4, they can have the truck! Sorry - had to try to be funny.... been cursed like that all my life...
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! Last edited by Luvlegs; 12-08-2007 at 05:00 PM. |
LoJack and a viper alarm!
#4 | |
The Original HotRod KnifeMaker
![]() Join Date: Jan 2007
Dave 69 GMC SWB 2WD 454 Turbo 400 |
Don't waste your money on an alarm. I work for a GM and Land Rover dealership and I get paid to remove alarms and security systems. I have not had one yet (including factory alarms) that I could not disable, and I am not a even a theif. The best thing you can do is to put a kill switch in your ride. It cost less to buy and most thieves would not waste the time to look for it. I put a kill switch in my old cutlass that basically was a series of switches that all had to be in the correct positon to start and run the vehicle (my brother liked to "borrow" my race car, after the switches he couldn't). The only other option I would consider (if I had an unlimited budget) would be a lojack.
A sweet 2000 Deville..... |
i put a viper in my '69. it wasn't too hard to install. i really only wanted the remote keyless entry part of it. but in addition to that i put a kill switch in like mentioned above.
i extended the "hot" wire from my distribtor inside the cab and placed a toggle switch under the dash against the drivers side kcik panel, just above the e-brake release handle. i have had no problems with it and it has kept people from driving it off. |
Living In The Past
This is not to offend anyone, but I dont see the value of dogs and guns when these threads come up. I have dogs and guns too but I know they wont do me any good when I am in the store/workplace and my truck is in the parking lot, or rest area, or if I hiked off to my fishing spot and had to leave my truck a quarter mile away.
Mine is not on the road yet but I am adding a fuel shutoff with a trick micro switch that is hidden and controls a relay. the trick part is that it takes a special way to turn it on that I wont divulge, But I would also like another deterent, and not just rely on the one. Yes I know there is the saying that if a theif wants it bad enough they will figure out how to get it, but the more deterents and such you can add make that thief really have to want it even more. So how much does that lojack cost? |
you could try the kind of immobializer that you have to push in your lighter while u start it
Travis
travis_moffatt@hotmail.com ![]() 1969 Chevrolet C-10 LWB, 350c.i., TH350, In Pieces. 1991 GMC Sonoma, IROCS s10 grill 1963 Ford Galaxie 351/C4 |
Active Member
Desrt Eagle
Sierra Grande Club
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
Eat My Rust
Kill switch all you want, but don't you just need to run a wire from the (HEI) distributor to the battery, and a screwdriver to the starter? Thats how we test-fired my truck...
My idea, since my column shifter lever is already kept in place by cotter pins, Ill just take the shifter with me when I leave. Good luck forcing it out of park. |
#13 |
![]() Join Date: Oct 2005
My thoughts are typical alarms are kinda a waste....yeah they are somewhat cool with long reaching remotes, auto locks, remote start, chirp noises, blinking lights, and the lovely alarm sound that everyone tends to ignore.
I say keep it stealthy......once the thief sees a blinking alarm light or an "alarm decal", it just pre-warns him of the obstacle. The more hoops you make him jump through to steal it, the less likely he will. Have an electrical shut off switch (like what's require for race cars) hidden some place (Painless even makes one that uses a wireless remote), then a simple ignition cut off (easy with an HEI) switch hidden somewhere, Then maybe one of those steering wheel club things, and finally, a fuel cut off (easy with an electric pump, but a little more involved with a mechanical pump....but doable) So the guy gets in the truck (hell..leave it unlocked so he doesn't screw up the door), probably gets the club off pretty easy, then messes with the ignition only to find out there is no power. Let's say he's prepared and figures all that out, starts the truck and gets down the block only to have it die in the middle of the road......I think at this point he's gonna bail instead of trying to figure out the problem while it's in the middle of the road. For what a nice alarm system costs, you could easily do all these mods for less and in my opinion have better protection.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
#14 |
Put a 50amp switch in between the neutral safety switch. i did that on my 72 Blazer. It worked great.
#15 | |
1970 Chevy K20 Custom Camper 1996 Chevy Impala SS 2008 Chevy Avalanche LT3 2003 Honda Accord EX 2001 Hewes Redfisher 16 Fighting Lady Yellow Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=324118 |
#16 | |
Old Skool Club
![]() Join Date: Jun 2001
I'd thought about an alarm system, too. But it may just be that this is the route I take. Simple and easy and hard to by-pass. All you gotta do is interrupt the circuit to the HEI and you got it.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. Last edited by ChevLoRay; 12-10-2007 at 09:06 AM. |
#17 | ||
![]() Quote:
I just thought of a good one ![]() ![]() I like this one alot! Thanks guys for getting me thinking. Kevin LFD Inc. Last edited by Rokcrln; 12-10-2007 at 09:53 AM. |
#18 |
![]() Join Date: Dec 2006
The most effective anti-theft system I've ever had was a truck that wouldn't start until after about 2 minutes of cranking (my last '69 GMC). Somebody got in there and skinned the wires and tried to "hot-wire" it but gave up when it didn't start.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
#19 |
Broken Down
I am going to wire in a hidden kill switch to cut off power to my electric fuel pump it might start and run for a few minutes due to fuel in the carburator bowls but it won't get any further than the stop sign at the end of my street !!!
kenm78 1982 Chevy 4X4 Project truck ![]() ![]() ![]() ![]() “It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt” |
#20 | |
Eat My Rust
#21 | |
They only make .357Magnum, .44magnum, and the mighty .50AE
Which I have all three...kind of. ![]()
#22 |
Sierra Grande Club
cool! This one is mine...
![]() Kimber CDP pro carry .45
#23 |
Active Member
![]() Join Date: Jul 2007
Re: guns and rifles:
A cop friend said the law does not look favorably at someone shooting a person unless you are in immediate danger and can call it self defense. In other words shooting someone because he is stealing your truck may land you in jail and, worse, you may also be liable for damages. Sorry but that's the way this crazy system works. ![]() Also, thieves are very patient and very stealthy themselves. I had a bicycle stolen from my yard just yesterday. And in broad daylight while I was in the house. Never heard a thing. Dog didn't even bark. We suspect the neighbor's delinquent son or his friends. We figure that's why the dog didn't bark. Can't prove it though. With that said, I still keep a loaded pistol in my bedroom. Never know what crazy thing I may do if I see someone stealing my vehicles... |
#24 |
![]() Join Date: Nov 2006
If You Dont Think Dogs Work Come See Mikey, Sugar,joe, Maggie & Sadie. They,ll Change Your Mind Quick And There Not Even Guard Trained. As Far As Deturant I Highly Recomend A Fuel Shut Off Inline Just Out Of The Fuel Pump As Its Well Hidden, Also With My Points Type Trucks I Unplug The Coil Wire But Leave It As If Its Plugged In. Also Use A Chain And Lock To Secure Hood Down. Cheap & Easy.
I BELIEVE IN JOHN 3:16 |
#25 |
![]() Join Date: Jan 2002
I have removable steering wheels on two of my trucks and LoJack on one. I won the LoJack at a car show this summer. They said retail is $695.
The removable steering wheels are a great alternative to alarms systems. They won't stop thiefs from towing the truck but it makes it darn difficult to drive away. Besides if you were going to steal a car and looked in and saw it didn't have a steering wheel you would probably move on to the next one. The kit is made by Grant and costs about $100. Summit has them. Only draw backs are they only fit aftermarket wheels and it positions the steering wheel about 2 inches closer to you. Works best if you select a wheel with little to no dish. I swear by them. One of my trucks is a daily driver and I always remove the wheel and stick it under the seat. Takes about 2 seconds. I used to drive it to a park in ride north of Seattle and the truck was always there when I returned and thieves treated thosed lots like used car lots.
71 Cheyenne Super 4X4 SB 72 Cheyenne Super 4X4 SB 72 Cheyenne 4X4 SB |
