sway bar installation.
i still have the original suspension. and i just bought a front sway bar from brothers trucks, but the instructions i got for them suck, i dont understand it at all, so i was wondering if anyone has installed this, i need help, and if u have pics, that would greatly help.
thanks |
Re: sway bar installation.
I took a look at the picture on their web site and it looks like a standard style bar. Straight part bolts to frame in front of axil using the U shaped clamps and matching bushings. The ends with the holes get "Links" that run down to brackets mounted to the axil. I would guess that the brackets mount to the spring u bolts. I would mount those first, make sure you have the right one on the right side etc. Then mount the bar to the frame so that the links are straight up and down and the bar ends should be parallel to the road. Good luck.
cool thanks, i actually figured it out, i found some pics of someone who did it, i just didnt know where to drill the holes for the bushings, but i got it and have it installed now.
