12-09-2007, 02:26 PM | #1 |
FYI - HEI tach wiring harness now out from M&H
To all,
I just got off the phone with M&H Electrical Manufacturers and they have just come out with a replacement tach harness for 68-72 chevy w/HEI ignition. This comes with all of the correct connectors to just "plug-n-play". The M&H part number is 39695 and retails for around $27.00. Monty Last edited by montyrobison; 12-09-2007 at 02:39 PM. Reason: Corrected model years info |
12-09-2007, 03:33 PM | #2 |
Firefighter
Re: FYI - HEI tach wiring harness now out from M&H
Sweet!!!
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA |
12-09-2007, 08:03 PM | #3 |
its all about the +6 inches
its a length of wire with 2 femail spaid connections
12-09-2007, 08:21 PM | #4 |
Yep but for the plug and play guys it has the corect Tach 90* plug and the correct HEI spade clip as well with a factory look. I just sniped and cliped for mine but for some it is a good deal I guess.
Kevin LFD Inc. |
12-10-2007, 02:04 AM | #5 |
Snip and Clip, I love it.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
12-10-2007, 06:34 AM | #6 | |
1997 GMC Sierra Ext 1965 Mustang |
12-10-2007, 11:07 AM | #7 |
A friend of mine tells me they will also custom build harnesses for you. Say you want the HEI tach harness as mentioned above but.. you also have a one wire alternator. They can do that too (from what I'm told).
12-10-2007, 11:52 AM | #8 |
senior member
just installed a new complete dash harness for a customer on a 68 there product is really nice
69 GMC bagged |
12-10-2007, 01:32 PM | #9 |
70GMCer
Below is a link to the M&H wiring harness catalog for Chevy trucks. Go to page 28. That's where the #39695 tach w/ HEI harness is listed. I believe there's a little more to the harness than a length of wire with two spade connectors. I'm pretty certain it has the two conductor "V" connector that goes to the tach and the correct connector to attach to your HEI dizzy. The other conductor should go to a switched 12VDC source I believe. Hope this helps. Monty http://www.wiringharness.com/PDFS/TR...hevy_Truck.pdf |
12-11-2007, 09:15 AM | #10 | |
12-11-2007, 01:35 PM | #11 |
I have it on Lil' Red...worked perfect and easy to install.
Alex 1971 Lil' Red 350 SBC 700R4 |
