12-09-2007, 08:51 PM | #1 |
Kobalt compressor and the flying keyway
This is not a knock on them, just some fyi. I was blowing of some dirt on
the frame I was cleaning today and all of a sudden the compressor starts knockin and wailing. Run to turn it off, and I'm thinking fan belt loose. So I check everingthing the manual says.Call the 866 number.I give her my model ect. And she says see if the keyway is lined up with the little pulley. Nope I say. and she says, They fly out, look around you may find it. I did. She says I send you a belt, new pulley, a set scew, and a new motor. Thank you very much. She seemed to indicate that set screws loosen regularly and the key way flys out, so you want to use plenty of red locktite. No hassle, no Joe Friday,nothin, just bam. I run the checks, oil changes etc, but it doesn't mention the keyway nut. I never owned one with this much capacity befor so this may be common knowledge.
borderline crazy& crossing the border often |
12-09-2007, 09:26 PM | #2 |
Cultural Infidel
Re: Kobalt compressor and the flying keyway
Thanks for the heads up. I have the same model and will be checking it every time before I fire it up.
-Mark
posted via La-Z-Boy -Mark 1972 C-10 Fleetside 350/TH350 PS PB A/C Cab Sadly....Sold 1968 Short Fleet 350/TH400 PS PB Delivered by Fine69 Also sadly Sold! It may be that your whole purpose in life is simply to serve as a warning to others. A man is not complete until he is married -- then he is finished. |
12-10-2007, 09:56 AM | #3 |
I have the same one too and I hav not heard about this problem either. Mine is a few years old though and never had a problem. Maybe a newer manufacturing glitch?
Just an FYI the little loose piece is the "key" ....the groove that is fits into is the keyway. These must be using a square key. They give a little more latteral movement, which will allow you to align the pulleys over a wider range or to use pulleys with wider hubs for multiple grooves. Smaller "woodruff" keys are rounded on the motor shaft side. They cannot fall out unless the pulley comes all of the way off. These are usually more of a press fit situation, but not always. Straight keys are more user friendly |
12-11-2007, 12:41 AM | #4 |
This lady acted like they had a batch lately. She insinuated somebody forgot
the locktite. Appreciate the teach on the terminology. Anyways I made a puller for the pulley, realigned the pulley and put the key back in. The keeper part is gone who knows where. It ran it a little bit and the key kept on trying to walk back out. I tried to find a bolt with proper threads for the crankshaft on the motor and had no luck. Now it may have been wrong but I reached up there and hit the key with a little tack weld and it's there. It can be removed if I need to. Anyways I was back working.
12-11-2007, 07:34 AM | #5 |
The bolt may have left-handed threads. If it does, you will need a specialty hardware/fastener supplier to get one. It is not the most common thing.
12-11-2007, 06:48 PM | #6 |
The smaller pulley had the key and the keyway. What ever bolt and keeper
was in it was gone. I actually did think of that because you are right about that as the larger pulley is machined for left hand threads. So when i couldn't start anything I had in the threaded end of the motors crankshaft pulley I gave up and put the tack weld there. It may be blasphemy to a machinist or somebody like that but it worked and did not seem to unbalance the motor or anything. They are going to send me a motor, pulley, key, and a belt and the keeper for the key, don't know exactly how it looks. I imagine they will want me to return at least their motor and if that is the case, I can easily remove the tack from the keyway. If they had mentioned that you needed to check on this situation I would have gave it a look. When I mentioned that to the lady. She said it was not expected but it was happening lately and that i should not have a problem if I would just use the red lock tite. Thanks for your information and maybe this ounce of prevention will help anybody else with one of the to prevent the pound of care
12-11-2007, 07:22 PM | #7 |
No Matter What.
I have a small 15 gallon from Kobalt that the motor went bad in, it was still under warranty so I got it fixed for free. But I was kinda disappointed when I found out that coleman actually makes them.
Currently own: 89 Chevy Silverado Previously Owned:Starting with my first vehicle 86 Mercury Cougar /89 Olds 88 /88 Chevy S-10 /84 Pontiac Firebird(I miss it) /91 Chevy S-10 |
12-18-2007, 06:57 PM | #8 |
just to follow up on the Kobalt compressor. they sent me new motor, pulley,
fan belt, and key. The pulley on this one has been machined with set screws in it. Looking at it versus the old pully, I think they actually forgot to machine this pulley for any set screws at all. Anyway they took great care of everything. Got the parts in 4 business days.
12-19-2007, 06:23 AM | #9 |
If I owned a Kobalt compressor, I'd call and see if they didn't owe me a new motor, etc. It wouldn't hurt to have a spare!
12-19-2007, 12:46 PM | #10 |
I got the same compressor. I will have to check that out. Good post.
Support your local search and rescue team.... GET LOST! Originally Posted by DURRTY if some is good more is better too much ought to be enough........ |
12-19-2007, 02:02 PM | #11 |
someday it will be done!
Out of curiosity,did they want the old motor back?
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
