Old 10-12-2002, 04:31 AM   #1
COBALT
COBALT's Avatar
Where to get new rear U-bolts for coils?
Am I being silly to think I can just stroll into NAPA and get a new set? That's how I got the front ones. Anyone else have an angle on getting some new ones? I know I can get them from ECE, but I need them tomorrow or the next day!!!
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 10-12-2002, 04:47 AM   #2
OhioDan
OhioDan's Avatar
AutoZone carries some, but not all. I had to go to the local spring shop to get a set for my son's. Maybe you'll get lucky? Call around to the local parts houses. Hope this helps?
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 10-12-2002, 04:50 AM   #3
crazy longhorn
Fabricate till you "puke"
If you have a local spring shop, you should be able to get them there. I just take a sample in for measure(usually in pcs after the smoke wrench), & they bend the u bolts from stock lenghts & supply the nuts & washers .
crazy longhorn is offline   Reply With Quote
Old 10-12-2002, 06:38 AM   #4
MOTHERTRUCKERS
Any local spring shop can make them, ours are rolled threads not cut so you can remove them without a torch. We have stock length and longer for installing lowering blocks.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 10-12-2002, 11:38 AM   #5
slam33
slam33's Avatar
LMC has them
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 10-12-2002, 06:36 PM   #6
jostrans68
Jostrans68
jostrans68's Avatar
not sure about seattle But Right way spring in tacoma will have or can make them for ya..
Right Way Spring CO Inc
2545 South Jefferson Avenue
Tacoma, WA 98402
253-272-4022
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
Old 10-12-2002, 06:59 PM   #7
jnelson
do you need them now
I have a new set you can have, but ya wont get them yesterday
looking for a new project
jnelson is offline   Reply With Quote
Old 10-13-2002, 12:37 AM   #8
COBALT
COBALT's Avatar
Well, I managed to get the nuts broke loose, and managed to get one pounded up as far as flush with the trailing arm, but no luck getting them to come out. They're really rusted in there. I think I'm going to have to cut them.
Therefore....I'm not in a hurry any more. Thanks a bunch. I'll probably check out all the places you guys mentioned this week.
Seattle, WA.
Old 10-15-2002, 01:39 PM   #9
COBALT
COBALT's Avatar
Well, NAPA looked at me like I was nuts. I'll be checking LMC, ECE, and that place in tacoma.
I'll send jnelson a pm.
Thanks guys.
Seattle, WA.
Old 10-15-2002, 04:10 PM   #10
MikeB
MikeB's Avatar
I got a pair a couple months ago from LMC Truck. Ordered them on Monday, got them on Thursday. Had to "spread" one apart a little using a vise and sledge hammer.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 10-15-2002, 04:40 PM   #11
ScottH
ScottH's Avatar
Jnelson, if they are still available please let me know -> sdelvy55@aol.com
ScottH is offline   Reply With Quote
Old 10-15-2002, 04:53 PM   #12
Kas68c10
Kas68c10's Avatar
Got mine from GMCpaul
1968 SWB Stepside, 250,pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,Seat from a later truck with built in seatbelts, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,Weber k550cub carburator...WORK IN PROGRESS, Freeland MI , Just bought a 72 Jimmy!!!!!!!!!!!
Kas68c10 is offline   Reply With Quote
Old 10-15-2002, 06:03 PM   #13
Stepside
Gasser
I made mine. 3/4=16 threaded rod. This was back when nobody had longer ones for lowering blocks. Unless you wanted to settle for 1/2 or maybe 5/8. Lowering blocks weren't offered in nothing but 1 1/2, with the small holes. I made the 2" alum. blocks too. This was around 1982. They are still under there after this long. And yes, I have tested them... 573 dynoed, tunnel ram, stroked 386, small block HP. Muncie 4, Hayes gold series clutch and plate, sticky Mickeys and all. I used to be the master at changing carrier bearing rubbers. I know this is a big no-no nowadays. And I agree. Sorry for the long post. I like the sound of Ed's rolled thread u-bolts. If they are 3/4".
Stepside
:thud 70 sstep tubbed, Muncie, double hump, snowflake,
Stepside is offline   Reply With Quote
