12-10-2007, 08:42 AM | #1 |
Need help with motor numbers
I just pulled the motor out of my 68 C10 and I'm trying to figure out if its worth keeping or selling it, and buying a crate motor. I did some searching last night and figured out its a 350. But I can't figure out what the other numbers mean. I overheated the motor for the second time and it needs at a minimum a new headgasket. Not to mention I havent figured out why its overheating. Just trying to figure out what I have so I can get an idea of what its worth. ITs a complete motor from carb to to starter minus distributor. Anyway, I found the following numbers on the block.
3970010 V1207TM 04F368299 Any help would be appreciated. |
12-10-2007, 09:41 AM | #2 |
Re: Need help with motor numbers
The casting # 3970010 shows to be 302/327/350 2 or 4 bolt main. Probably a 327 or 350 since the 302 was the DZ302.
The TM part of your stamp code doesn't match that so maybe you are a letter off: TM 1956 265 m/t 155 2 truck/3100 TM 1978 305 LG3 U 145 2 LeMans I'd say pull a head and measure the bores, drop the pan and see what mains you have. If it's a 350 4 bolt, it would be worth keeping and rebuilding if you're looking to get a new eng anyway. Put in a new thermostat, radiator, hoses, and water pump and you're done. Really, those items are cheap and should be replaced if you just dropped the $ on a rebuild anyway. I got the above info from MORTEC and Nastyz28.com.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ Last edited by clay68c10; 12-10-2007 at 09:46 AM. Reason: added reference |
12-10-2007, 01:26 PM | #3 |
Addicted to Chevy
i ahve heard that converting a 2 bolt main to a 4 bolt is actally stronger than a regular 4 bolt main. true?
12-10-2007, 11:07 PM | #4 |
I've heard that too, I think it's if you're using the aftermarket splayed-bolt billet caps.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
12-11-2007, 12:18 AM | #5 |
It is stronger but how radical are you gonna build it? I'd buy a forged rotating assembly before worrying about 4-bolt mains.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
