Old 12-10-2007, 05:18 PM   #1
crosby
crosby's Avatar
HEI conversion
Hi guys. My buddy Bill is building a really nice 72 stepper, and asked me for help swapping the point distributor for an HEI, which he already has (in his barn). Any pointers on what wire to grab to power the coil? The cleanest neatest (proper) way to do this? I am not so good with wiring, and want to make sure I actually HELP him... Thanks for any pointers...
Crosby
1978 Chevrolet K10 stepside
NH
crosby is offline   Reply With Quote
Old 12-10-2007, 06:24 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: HEI conversion
These might help: http://67-72chevytrucks.com/vboard/s...ad.php?t=17403
http://www.oldengine.org/unfaq/hei.htm
http://rmcavoy.freeshell.org/HEI.html
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 12-10-2007, 06:37 PM   #3
Piece of Work
Cultural Infidel
Piece of Work's Avatar
Re: HEI conversion
Use a 12 gauge wire, crimp on the appropriate ends. Connect in the fuse block at Ign. unfused. Use an in-line 30amp fuse. Connect the other end to the dizzy.
The area circled in yellow is the connection in the fuse block.
-Mark
posted via La-Z-Boy
-Mark
1972 C-10 Fleetside 350/TH350 PS PB A/C Cab Sadly....Sold
1968 Short Fleet 350/TH400 PS PB Delivered by Fine69 Also sadly Sold!
It may be that your whole purpose in life is simply to serve as a warning to others.
A man is not complete until he is married -- then he is finished.
Piece of Work is offline   Reply With Quote
Old 12-11-2007, 08:25 AM   #4
crosby
crosby's Avatar
Re: HEI conversion
Thanks very much guys, a great help.
Crosby
NH
Old 12-11-2007, 10:03 AM   #5
nofords
Re: HEI conversion
In my 66 c10 I just used the same ignition on wire that used to power the coil. Seems to work ok, been running for 3 years now with no problems. I once tried to put HEI in a 72 and found the firewall and cap had a space conflict. I didn't care about looks then and needed to get to work so used the hammer method to free up some space. Not recommended if you lose a motor mount though........nofords
nofords is offline   Reply With Quote
Old 12-11-2007, 01:39 PM   #6
byrd
Union Electrician
byrd's Avatar
Re: HEI conversion
in 67-72 years for sure the original coil 12 volt supply is a resistive wire and needs to be replaced with regular copper automotive wire. If you do not replace you willmost likely have voltage and ignition issues.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 12-11-2007, 01:40 PM   #7
byrd
Union Electrician
byrd's Avatar
Re: HEI conversion
-Mark
#12 wire is only good for 20 amps, I would reccomend using #10 with a 30 amp fuse.
Zip:40272
