12-11-2007, 12:04 PM | #1 |
68 GMC leaf spring or coil
Hi, Im kind of new to the forum and was wondering if a 68 GMC short stepper would have coil spring or leaf spring suspension. If it is leaf spring, how could i make it coil spring? I am wanting coil spring because i want to bag it.
Nick Old pic of my 72: http://img340.imageshack.us/my.php?image=img0435co5.jpg 04 Silverado Daily Driver 68 GMC short step http://67-72chevytrucks.com/vboard/s...d.php?t=379665 "I'll beat you to the gas station!!" |
12-11-2007, 12:29 PM | #2 |
Re: 68 GMC leaf spring or coil
anyone?
12-11-2007, 12:40 PM | #3 |
My 67 long step is a leaf spring truck.
"Do the things you fear to do and the death of fear is certain" |
12-11-2007, 12:43 PM | #4 |
if it's a GMC then it came stock with a leaf spring set up but could be ordered with coils. chevy's are the opposite
don't know what exactly would need to be done to convert from leaf to coil but i'm sure someone else on here will tell ya
(Only) Member of the CPNE Fan Club Aint that the truth 67 C-10 350 with 3-speed tranny and 308 gears swb step 82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine) 72 Chevy K20 Suburban (future project) 70 Chevy K20 now 68 GMC K2500 2003 Chevy 2500hd ccsb 4X4 (daily driver) |
12-11-2007, 12:58 PM | #5 |
ok thanks for the input. anyone else?
12-11-2007, 01:19 PM | #6 |
Truck and auto performance nut
the trailing arms, a pan hard bar and mounts, the coil springs, the shock brace, convert the rear axle for coil mounts....and probably a few other things I'm forgetting.
or...buy a coil spring frame/parts truck and just swap it over.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
12-11-2007, 01:23 PM | #7 |
Thank you for the input. I'm going to look for a coil spring truck. I would be less hassle and probably cost less. Thank you once again
12-11-2007, 03:28 PM | #8 |
Active Member
picked up a 67 short step chevy it has leaf springs..... but im converting it.
1969 C10 SWB /350 vortech/th400 1968 SWB build (in progress) 1969 SWB build (my son's future project) 1968 camaro yellow/white stripes (wife's car) 2011 GMC reg cab short bed 2wd daily driver 5/7 drop on 22's 1972 K5 Blazer 13"/11"lift,38"M/T MTZ's, 3" cust exst. 350/350 (sold it ) |
12-11-2007, 03:35 PM | #9 |
Active Member
In that year GMC's came with leaf springs standard. I'm not sure about special orders though. My 68 has them.
I also believe that they're less hassle than the coil springs. I have a 69 Chevy with coils and the 68 with springs and really don't notice much difference in the ride. There are those, however, that prefer the coils in the rear. |
12-11-2007, 03:55 PM | #10 |
Old Skool Club
Uhhh, the easiest way to know for sure involves getting down on at least one knee and looking underneath. You could look at the SPID on the glovebox door, but looking at the rear end setup is the surest way.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
