Old 12-11-2007, 02:11 PM   #1
bowtieboy93
bowtieboy93's Avatar
Rivet Removal
Im gonna have to remove rivets in the near future and was wondering what you guys found out to be the easiest way to get them out. Thanks
Travis
travis_moffatt@hotmail.com
1969 Chevrolet C-10 LWB, 350c.i., TH350, In Pieces.
1991 GMC Sonoma, IROCS s10 grill
1963 Ford Galaxie 351/C4
bowtieboy93 is offline   Reply With Quote
Old 12-11-2007, 02:19 PM   #2
moneyguru
moneyguru's Avatar
Re: Rivet Removal
How big a rivet are you talking about?
small ones can be drilled out by using a drill bit just a little bit smaller than
the hole the rivet is in.
"Do the things you fear to do and the death of fear is certain"
moneyguru is offline   Reply With Quote
Old 12-11-2007, 02:25 PM   #3
72chevy327
Re: Rivet Removal
I use a air hammer with a sharp punch. Drilling works good to, I like to use a center punch first.
72chevy327 is offline   Reply With Quote
Old 12-11-2007, 02:26 PM   #4
bowtieboy93
Re: Rivet Removal
whoops sorry should have said what kind, im talking about like the big ball joint ones or crossmember, thanks
Travis
Old 12-11-2007, 02:32 PM   #5
Rokcrln
Rokcrln's Avatar
Re: Rivet Removal
Plasma cutter all the way! But if you don't have one then I would grind off the head flush with the frame or control arm and use a big punch or air hammer with the punch tool.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 12-11-2007, 05:37 PM   #6
72BLUZ
72BLUZ's Avatar
Re: Rivet Removal
Use A Die Grinder, Cut A Slot Like A Screw Driver. And Use A Air Chisel To Push It Off.
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream.
It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan
72BLUZ is offline   Reply With Quote
Old 12-11-2007, 06:14 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
Re: Rivet Removal
If they are where you can get at them easily I just use a large chisel sharpened on one side. Clamp it in some vise grips and hit it with a BFH. The heads usually pop right off. Punch out the rest with a good sturdy punch clamped in the vise grips. Be sure and wear some heavy gloves and safety glasses. If you can't get a good swing at the chisel then I would go with the grinder or air chisel method.
LockDoc
Leon
Old 12-11-2007, 06:44 PM   #8
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Re: Rivet Removal
with Rokcrin...I don't have a plasma cutter but the grinder and punch work great. Just remember to grind the head flush.
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 12-11-2007, 07:46 PM   #9
jasonb72
PorterBuilt Man Crush
Re: Rivet Removal
I have always used the grinder and made a 2 cuts all the way down to the frame, making 1 horizontal and 1 vertical will make the air chisel and punch easier.
The 72 will live again
jasonb72 is offline   Reply With Quote
Old 12-11-2007, 08:32 PM   #10
bad6772
Official Site Guitar Shredder
bad6772's Avatar
Re: Rivet Removal
center punch the hole and grind the head flush...works est for me ,a drill bit also will work....
bad6772 is offline   Reply With Quote
