Old 12-11-2007, 03:56 PM   #1
dan42
dan42's Avatar
gas tank leak -
I just filled my tank and I started to smell gas, and pulled the seat back to find it leaking - I think it was from the inside ring, not the outside, but I was wondering what the fix was -? Not fill it so far? Is there a seal?
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 12-11-2007, 04:29 PM   #2
sick69
sick69's Avatar
Re: gas tank leak -
There is a rubber "o" ring under the sending unit. The outer lock ring is on top of the sending unit. Would be my guess the "o"ring is shot and needs to be replaced,,,,,yesterday. I would start there and see if that fixes it. Most of the board vendors should have the "o" ring and probably won't cost 10.00-12.00 plus shipping.
Until you get it replaced don't fill it up so far.
OR you could swap to a blazer tank mounted in the rear under the bed.
Just my .02
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 12-11-2007, 05:06 PM   #3
bowtieboy93
bowtieboy93's Avatar
Re: gas tank leak -
just remember: DONT WELD IT!!!
Travis
travis_moffatt@hotmail.com
1969 Chevrolet C-10 LWB, 350c.i., TH350, In Pieces.
1991 GMC Sonoma, IROCS s10 grill
1963 Ford Galaxie 351/C4
bowtieboy93 is offline   Reply With Quote
Old 12-11-2007, 05:59 PM   #4
dan42
dan42's Avatar
Re: gas tank leak -
Thanks, guys, that's where I'll start -
Philippians 4: 6-7
Old 12-11-2007, 09:09 PM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: gas tank leak -
I saw a gas kit the other day in Advance for the twist locks with a assortment of o-rings.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
