Old 12-11-2007, 07:38 PM   #1
yenko427
yenko427's Avatar
pics of limited slip
I just pick up a diff. for a 100 buck a dont what im looking at. It is a 12 bolt with a open diff. it has two small gears and two bigger gears in the open parts. The guy I bought it from says it is a posi but I called a friend a he says its a limited slip. I have looked in all the other threads but dont see any pics to show me. Thanks for the Help!
yenko427 is offline   Reply With Quote
Old 12-11-2007, 08:15 PM   #2
hdflstf
hdflstf's Avatar
Re: pics of limited slip
Usually limited slip and posi are used somewhat interchangeably. A posi would have a visible set of springs between the two bigger gears. See picture for an example.
hdflstf is offline   Reply With Quote
Old 12-11-2007, 08:30 PM   #3
yenko427
yenko427's Avatar
The place where the spring are there is gears. Maybe I just bought another one wheel diff. ?@"Q.
Old 12-11-2007, 08:48 PM   #4
hdflstf
hdflstf's Avatar
If you turn one gear, does the gear on the other side turn the opposite direction? If so it's an open (non posi) unit.
Here's another picture. Is there anything between the two bigger gears or just a shaft that runs between the two smaller gears?
Old 12-11-2007, 08:59 PM   #5
yenko427
yenko427's Avatar
just shafts
Old 12-11-2007, 09:49 PM   #6
wibilly
wibilly's Avatar
sounds like you got another open dif
common sense isn't so common anymore
wibilly is offline   Reply With Quote
