Old 12-11-2007, 09:45 PM   #1
El Jay
Gone to greener pastures
Cowl drains/Dumb question of the night
How do you clean the cowl drains?
The rainy season is here & I have water running down the right side kick panel & dripping from the center of my dashboard. I don't particularly want to rust out my floorboard & I don't want to drown my stereo.
Thanx,
El Jay
El Jay is offline   Reply With Quote
Old 12-11-2007, 10:31 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Cowl drains/Dumb question of the night
First gently pruy the wiper arms up using a rag to protect the paint.Open the hood and you will see the screws holding the cowl on.There are also bolts in the door hinge area.Then you can remove the cowl and reach down each side.I usually use a shop vac.They make a screen for the cowl vents which will help keep the trash out so they can drain.I think i remembered all the holding fasteners but if not someone will chime in.They may with better instructions anyway.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-11-2007, 11:17 PM   #3
El Jay
Hey, Thanx.
I was pretty sure the cowl had to come off, but I wasn't sure. I wanted to check before trying to attack screws & bolts that have been in place for 35 yrs. I've seen aftermarket "trash screens"; I think I'll get a set & install them @ the same time.
El Jay
'69 Chevy 1/2 T, LBSS
'72 GMC 3/4 T FS
'72 Fury, Gran Coupe
And a "Merry Christmas" to you.
I despise "Happy Holidays." It's Christmas, for Christ's sake. Jesus is the reason for the season
Old 12-11-2007, 11:34 PM   #4
sodak69c10
sodak69c10's Avatar
i make my own screens with some strips of steel window screen i had , i cut the strips then lay them down so that the attachment screws would hold it in place worked great for me
,Clint
LOUD PIPES SAVE LIVES
69 C-10 short stepside 406 sbc, 02 YAMAHA WR250F, 07 SUZUKI SV650S, 81 Grand Prix 355 sbc, 81 XT 500 YAMAHA
sodak69c10 is offline   Reply With Quote
Old 12-11-2007, 11:52 PM   #5
El Jay
Thanx, sodak69c10,
I'll keep that in mind when I open the damn thing up.
El Jay
Old 12-12-2007, 07:46 AM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
Open up both vents and 75-80 mph down the interstate usually does it.
*Remember to keep your mouth closed and both windows down. Goggles help too
You can also remove the inner kick panel vents by removing the two screws that hold the handle on and pull down on the top pin (it's got a spring on it) and pull the whole vent door out. This is where all the debri falls to.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-12-2007, 09:05 AM   #7
Ackattack
Ackattack's Avatar
there are a couple of screws along the top of the cowl too.
Ackattack is offline   Reply With Quote
Old 12-12-2007, 09:28 AM   #8
Rokcrln
Rokcrln's Avatar
What also works is to take your wife's house vac and use it to clean out the kick panel vents. "But money mine was just to big!"
EL Jay~ Were in Nor Cal are you hiding?
Kevin
LFD Inc.
near Sac.
Rokcrln is offline   Reply With Quote
Old 12-12-2007, 05:19 PM   #9
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
NAPA has a tool that lifts and separates (sounds like a bra, huh?) and will make it soooooo easy to get the wiper arms off of the shafts. You may only need them once....then you may need them again. Any work that you have to do on your wipers will be met by an easy streak, if you have them. They won't scratch the paint, either.
Member Nr. 2770
Old 12-13-2007, 12:07 AM   #10
El Jay
Thanks guys.
But Y'all opened up a few new questions.
Drive down the interstate @ 75-80, which gear. I can come outta 2nd & into "D" at about 75. Damn 4.11's are slowin' me down.
Rocket ship off the line, but no top end.
I'm thinking "Gear Vendors" to cure that li'l problem.
Use the "wife's vacuum" to clean things out.
Whatsa wife?
Thank you to everybody for your input!!!
Old 12-13-2007, 01:49 AM   #11
72armyswbtruck
72armyswbtruck's Avatar
Originally Posted by El Jay View Post
Whatsa wife?
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 12-13-2007, 07:15 AM   #12
Luvlegs
Luvlegs's Avatar
Whatsa wife?
The same as 3 completed trucks a year... more or less....
Your choice: Pick one or the other.
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 12-14-2007, 09:05 AM   #13
Bucky71
This probably the seal on the wiper motor. Mine leaks too.
Bucky71 is offline   Reply With Quote
Old 12-14-2007, 05:14 PM   #14
El Jay
Antioch, Gateway to the Delta.
Used to be a nice little town, but then about 80,000 people found it & moved here.
Old 12-14-2007, 07:05 PM   #15
sodak69c10
sodak69c10's Avatar
DITTO, until i took the tube of silicone to it(now if only my windshield didn't leak)
i actually have another cure for the leaves , this is what i am doing , shave the vents from the cowl, install vintage air kit
,Clint
Old 12-14-2007, 07:42 PM   #16
PanelDeland
When i put the screens on mine i used bread bag ties to hold them in place on the cowl then after all the screws were started i just untwisted them and removed.I couldn't hold everything steady enough otherwise.
