Old 12-12-2007, 10:36 AM   #1
grebus1
grebus1's Avatar
Electrical question '72 Burb
I had a weird thing happen on my Burb yesterday.
Went for a short drive, turned it off and went to start it again, but the starter wouldn't engage. All the inside/outside lights remained on and bright. I put my battery charger on it for a couple minutes and then flipped the charger to power start and it fired right up. Removed the charger and it started 3 or 4 more times no problem. Any thoughts?
The battery is about 5 yrs old, so I suspect that and maybe a poor connection at the battery, but what else should I check? Could it be the starter/solenoid?
'72 Chevy Suburban Custom Deluxe 10, 402/TH400
grebus1 is offline   Reply With Quote
Old 12-12-2007, 11:20 AM   #2
cdowns
cdowns's Avatar
Re: Electrical question '72 Burb
power to starter goes thru neutral safety switch if it wasnt all the way in park or if alignment is off will cause a dead starter circuit
