12-12-2007, 02:42 PM | #1 |
T-case to frame please help
I took a mounting bracket off a `69 blazer today and bolted it to my frame,now the bolts that go in the right side of the T-Case will not go in.I took the upper transmission mounts out & they almost line up. the mounts seem too thick,they are 1 1/8in.thick I called Carquest they only show one from `68 to `81.pn#31-2107 which is what I bought. Maybe i have to drill holes in my frame? I would appreciate any input,Thanks Philip
12-12-2007, 03:48 PM | #2 |
Re: T-case to frame please help
Do you have the correct factory crossmember for the TH350/NP205 combo?
Tim |
12-12-2007, 04:33 PM | #3 |
Post Whore
The side mounting bracket you have from the 69 K5 may be for a Dana 20 transfer case instead of an NP205. Can't guarantee they are different, but I know the crossmember is different for a Dana 20 compared to the NP205 so likely the side bracket is different too.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
12-12-2007, 04:45 PM | #4 | |
I'm a poor spectator
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! 1979 Ford F150 4x4 SWB Built Ford Tough!!! 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
12-12-2007, 06:06 PM | #5 |
thanx for the help guys, I think i need a different cross member.This truck had a v-6 4 speed,rockwell t-case from factory. When i put the v-8 cross member in i moved it ahead 2 in. & the trans. mount lined up so i thought i had it made until i got this side bracket maybe it is different also. I do some hunting for new parts tomorrow. THIS SIGHT IS GREAT LOTS OF AWSOME PEOPLE,Philip:
12-13-2007, 05:39 AM | #6 |
Your transfer case might also hit the floor pan if you try to use the crossmember that you have.
Tim |
12-13-2007, 07:33 AM | #7 |
Maybe it's me, but is that crossmember upside down, can't really see, don't have my glaases on... J.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
12-13-2007, 07:43 AM | #8 |
If that crossmember was from a 221 then that's your problem. There's a 1 in difference in height between the 221 & the 205 crossmembers. You need to get a crossmember from a truck ( 69-72 )that had a np205 t-case, standard or auto dosen't matter there both the same. I'm not sure about the torque mount that may also be different.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
12-13-2007, 10:24 AM | #9 |
Post Whore
I should have added, I used 1" spacers to lower my Dana 20 transfer case crossmember to fit my NP205. Otherwise the NP205 was hitting the floor like mentioned above in relation to the Rockwell T221 crossmember.
12-14-2007, 05:04 AM | #10 |
12-14-2007, 04:50 PM | #11 |
I got a crossmember today for a 205t-case, it is one inche deeper than the original.thankyou to all of you that helped me get out of this bind,and no its not upside down,that would really put it waaaaaaaaaaaaaaaaaaay high.
12-15-2007, 12:24 AM | #12 |
OK, glad I was wrong
12-15-2007, 05:31 AM | #13 |
Post Whore
Any chance you can get some comparison pics, always nice to have pics to show differences.
12-19-2007, 02:48 PM | #14 |
Thanx for the help everyone,Yukon Jack,sorry it took me so long to get back I just got my old crossmember out last night,I hope you can see the comparision pics OK. the 205 crossmember measured about 1/2 in. deeper than the t-221. I installed it today & it went together good.Y-jack I like your truck,Philip |
