Old 12-12-2007, 07:12 PM   #1
Sinister
Between Trucks...
Sinister's Avatar
Question Repop Grill question...
I just received a repop outer grill for my '69. I also got the brackets and hardware kit. In the kit there are these aluminum pins with rivets on the end, are these for attaching the grill to the brackets? If they are, how do I go about doing that?
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 12-12-2007, 07:32 PM   #2
tcb-1
Nothing to see here.....
tcb-1's Avatar
Re: Repop Grill question...
sin,
you will need get a pop rivet gun to attach the rivets for the outer grille supports. these "guns" are like a pair of pliers that pull the pin through the rivet and at a certain tension, they will pop off. you can either pick up a cheap pair through places like Harbor Freight or the nicer ones through Sears.
I just installed a 69 grille myself. pretty easy. post a pic of your truck with it's shiny new teeth when you get it installed!
tcb-1 is offline   Reply With Quote
Old 12-12-2007, 08:41 PM   #3
Sinister
Between Trucks...
Sinister's Avatar
Cool, thank you...
Beat it to fit,
Old 12-12-2007, 09:39 PM   #4
byrd
Union Electrician
byrd's Avatar
Make sure you install the rivets with the grill in the truck bolted to the brackets and the the fenders and set where it needs to be for proper alignment
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
