![]() Join Date: Jul 2007
Ram Assist vs PS
Heres the dilima I am building a 67 Chevy SWB from the ground up and want to stay halfway with the same year parts but am going to use my front end off my 71 GMC for the disc brakes and safty. The current set up on the Chevy is man steering which will be easier to install on the frame the ram assist or ps and which would you go with. Thanks for all the help from the experts I know are out there.
Old member
Re: Ram Assist vs PS
If your adding the 71 front end I would go with the power steering off of it. The power assit isn't that great from what I remember.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Jamie Hyneman is my twin
![]() Join Date: Nov 2005
Power ram is scary!
My 67 nova had one, and talk about bump steer. If the valve is not adjusted just perfectly, you can chase it all over the highway. It worked great for in-town driving, but at 67-75 you'd better not be sleepy.
Justin SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD Color Wiring Diagrams Now in High Resolution V8 and Cab and Cab and Chassis |
![]() Join Date: Aug 2005
'62-'67 Nova front ends were scary period! Yes, the control valve has to be adjusted properly, but if it is too touchy, it probably needs to be rebuilt or replaced. The biggest problems with ram-type P/S is that they are a bit prone to leaking and since it uses the same steering box as manual steering, the ratio is slow for power steering. Also, the wheel doesn't return to center by itself all that well. You can buy new hydraulic cylinders and valves if you go with the ram type.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. Last edited by Bob B.; 12-13-2007 at 03:04 PM. |
Old Skool Club
![]() Join Date: Jun 2001
Besides all the extra linkages, they usually leak over time. They're old-school, for sure.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Windy Corner of a Dirty Street
Can that ram assist BS and use a power steering gear box. My 68 GMC originally had ram assist, which I got tired of fixing the leaks and herding it around on the highway. Finally hiked it and the manual steering gear in the trash and used a power steering gearbox instead. After I did that I wondered why I didn’t do that years ago.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
i'm guessing the ram asist can't be all that bad or it wouldn't hav been used in corvetts for so long
common sense isn't so common anymore |
