12-13-2007, 01:17 AM | #1 |
Old member
Electric windows
Ever since I've put the electric windows in my truck they have been hard to get up. They come down nice and easy, but up is another story.
Should they have relay's on them to make this better or do you think it's something else? Both sides do this.
12-13-2007, 08:31 AM | #2 |
It's a catastrophic success.
Re: Electric windows
Sounds like you may have an alignment problem. Watch the glass going up and see if it tries to shift forward or back, this causes the glass to bind the felt track.You will need to play with the guides to make it track even.
12-13-2007, 10:38 AM | #3 |
i put them in mine too and i have the same problems. what kit are you using? i used the cheap kit from LMC truck. my problem was the tracks. the rollers are flat spotted and when ever the roller is stuck on the flat spot is when i binds. it eventually stripped the gears that attach to the regulator.
good thing about LMC is they have replaced the entire kit on four occasions becasue of the same reason. |
12-13-2007, 12:59 PM | #4 |
Senior Moment
I used A-1 http://www.a1electric.com/index.htm with no problems what so ever and couldn’t be happier. I made sure all my tracking was in good shape along with all the rollers. If things aren’t lined up right it won’t matter what kit you have.
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 Last edited by 1970 CST Short Wide; 12-13-2007 at 01:03 PM. |
12-13-2007, 03:41 PM | #5 |
Old member
I'm thinking it maybe alignment issue. I'm going to check it out this weekend I hope when I start work on the interior since the tear down. Thanks ... Oh I don't remember the name of the kit I'll look and see if I can find it.
