Old 12-13-2007, 09:47 AM   #1
LowStep79
73-80 81-87 Cabs
I'm sure this has been covered before but I don't remember exactly. To use a 73-80 nose like I have I have to have a 73-80 cab correct? Or are they interchangable? Got digging into mine and found the cab is worse than I thought. Needs cab corners, rockers, floorpans, kick panels, ETC. So If I could find a cab that is in much better shape that's what I want to do.
LowStep79 is offline   Reply With Quote
Old 12-13-2007, 10:02 AM   #2
Russell
Professional Grade
Russell's Avatar
Re: 73-80 81-87 Cabs
The 73-80 front clips fit on either with no modifications to the cab less switching the correct wiper linkages and cowl on, while you have to modify an older cab to put the newer front clip on for the hood hinges and the other type of cowl.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 12-13-2007, 05:46 PM   #3
bigtruck81
if you put a 73-80 clip on an 81+ cab you will have slits in the cowl where the 81+ hood hinges recess into. if you would seal them off, there would be virtually no difference in the cabs.
bigtruck81 is offline   Reply With Quote
Old 12-13-2007, 06:13 PM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
if you put a 73-80 nose on the 81-87 cab you have to switch the wiper linkage as the newer cabs have longer nubs on em and it will hit the hood
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
