05-03-2002, 06:16 PM | #1 |
AC Stuff
Hope I don't wear out my welcome, but I have lots of questions.
Truck has (had) factory AC. I have the original parts, but installed an aluminum intake. Can I still put things back the way they were and get some cool air? It gets hot here in the summer. Thanks Paul |
05-03-2002, 06:31 PM | #2 |
Old member
You should be ok with the intake most of your acessaries hook to the heads. Depending on what brackets you have two of the bolts that hold the compressor on are for the intake. Heater hoses should go back on to stock locations. Check out my ac in my signature pics.
------------------ Andy 71's Are for ever!!! or 67,68,69,70,72 71,factory tach,tilt for straight drive,gauges,ac,speed warning,clock,305 HO TPI with 700-R4, lowered 2" & 3" ,and 17" Chrome Stealth wheels www.geocities.com/chevy71tpi/main.html [This message has been edited by Andy4639 (edited May 03, 2002).] [This message has been edited by Andy4639 (edited May 03, 2002).]
