Old 12-13-2007, 08:09 PM   #1
70C10Step
70C10Step's Avatar
454 Swap???
Well my project has jumped into high gear. I have gone from building a 350 to picking up a complete 454 for $300.00 this coming weekend. Now I am going big block and I need direction on how to make this happen. Any advice would be greatly appreciated...
All Toys:
1971 C10 Fleetside - I needed it!
1970 C10 Stepside - Midlife Crisis
1969 C20 3/4 Longbed - Beast!
1966 Mustang Fastback - Daily Fun
1965 Mustang Fastback - Money pit!
70C10Step is offline   Reply With Quote
Old 12-13-2007, 08:58 PM   #2
chevy72blu
chevy72blu's Avatar
Re: 454 Swap???
Try the search function, this one comes up a lot.
You are going to need a set of new towers. The 70-72 BBC ones are quite pricey, but 73-87 SBC do the trick, though you may have to drill new holes in your frame and front x member. I used them with a 73-87 front member on my 72 with a BBC - there are pics on my build thread (sig).
Not a hard swap - BBC's were available in these trucks from the factory.
Thats a damn good price, running or not. Gonna rebuild it?
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 12-13-2007, 09:22 PM   #3
70C10Step
70C10Step's Avatar
Re: 454 Swap???
Yes I am going to rebuild it. I will get some new heads also to reduce weight. I plan to build for some street performance... I plan to break it down next week and take the block in for the first stage of the build... I need to find out my options...
All Toys:
Old 12-13-2007, 10:01 PM   #4
webfoot
Re: 454 Swap???
New heads aren't goin to save you any weight unless you go with some aluminums. Patriot Performance is supposed to be releasing BBC heads this month for around $1300/set, complete.
If it is a truck motor, they are likely open chamber peanut port heads, so it probably won't be a rocket as is.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 12-14-2007, 04:30 AM   #5
70C10Step
70C10Step's Avatar
Re: 454 Swap???
Aluminum heads are in the future for this build. Phase 1 is figuring out how to build this motor for a liittle bit of performance without getting crazy...
All Toys:
Old 12-14-2007, 08:19 AM   #6
496stroker1
Re: 454 Swap???
chevy hi performance did testing on those patriot heads in the nov issue. pretty good power but they look a lot like those procomp heads made in china.... made good power but check out this
http://www.boatstoreonline.com/procomp.html
496stroker1 is offline   Reply With Quote
Old 12-14-2007, 09:12 AM   #7
webfoot
Re: 454 Swap???
Patriot is pretty well known for their low buck/high quality SBC stuff, so I'll give them the benefit of the doubt until I see some "real world" results. (i.e., not from a car mag)
Just my .02, run that 454 as is, and start accumulating parts to build that thing up right, rather than spending money on stuff in the intermediate. (think 496!)
-me
Old 12-14-2007, 01:19 PM   #8
danny6892002
danny6892002's Avatar
Re: 454 Swap???
are the BF goodwrench 454(14015445) good for performance because i just bought one and i want to know if is worth fixing
danny6892002 is offline   Reply With Quote
Old 12-14-2007, 02:10 PM   #9
DieselEater
DieselEater's Avatar
Re: 454 Swap???
Any BBC engine questions can be answered here......These guys are PRO'S!!!
http://www.chevelles.com/forums/forumdisplay.php?f=13
In your situation, I'd run it as is to see if you like it.......If it feels weak then just bolt on some closed chamber ovals like a 702 and you should be happy. If you still don't like the power, then it could get expensive!!!
A........
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
http://profile.myspace.com/index.cfm...ndid=127691959
DieselEater is offline   Reply With Quote
Old 12-14-2007, 04:41 PM   #10
stumpy
stumpy's Avatar
Re: 454 Swap???
A........
Why closed chambers? Don't the open chamber heads make more power? It seems like you can find 781's everywhere fairly cheap.
67 C10 LWB Fleet
02 Chevy K1500HD Crew Cab - Stock LQ4 & 4L80E, 3.73's, my DD
08 Impala SS - Wife's DD
96 Impala SS - stock engine with bolt-ons(Wifes race car),
96 Impala SS - 496 BBC race car 9.69 @ 143
stumpy is offline   Reply With Quote
Old 12-14-2007, 04:53 PM   #11
webfoot
Re: 454 Swap???
Open chamber heads have low compression, but a built set of 781s or 049s with some dome pistons can make great power.
-me
Old 12-14-2007, 05:40 PM   #12
stumpy
stumpy's Avatar
Re: 454 Swap???
I see, so even if marginal, it's a gain over say a peanut head. How much of a gain are we talking tho?
67 C10 LWB Fleet
Old 12-14-2007, 06:23 PM   #13
496stroker1
Re: 454 Swap???
peanut ports are tiny, good for towing. 781's are good heads just need a dome to get compression outta them. do a search on ebay for bbc heads and you will see how much difference between peanut and large oval heads there is. also hotrod did a dyno test on a 496 chevy stroker few years ago (never could find it on the net but i got it in the mag) with the usual decent sized hyd cam, dual plane intake blah blah.... but used bone stock 702 or something heads with large oval ports, closed chambers, tiny valves (something like 2.06 1.70) made 490 hp almost 600 ft pounds:chevy. pretty good for old techmology
Old 12-14-2007, 06:25 PM   #14
496stroker1
Re: 454 Swap???
should also say those peanut port heads wicked for bottom end but the engine would fall flat on its face past 4000 rpm
Old 12-14-2007, 06:27 PM   #15
70C10Step
70C10Step's Avatar
Re: 454 Swap???
Wow! I cannot wait to get this build going... I am going to take my time and do it right!
All Toys:
Old 12-15-2007, 05:44 AM   #16
chevy72blu
chevy72blu's Avatar
Re: 454 Swap???
Scat recently released a 1300 dollar (shipped) completely forged rotating assembly (steel crank), stroker kit. Great price, and with a 10.2:1 compression ratio and 496 cubes, those heads and a nice cam, you'll be verrrry happy.
If you are going to rebuild the motor from a bare block, why not go with a 4.250 crank?
RIP EastSideLowLife
Old 12-15-2007, 06:05 AM   #17
smoky02
Location: Sunny, Florida, some might call it South Alabama
Re: 454 Swap???
What size Carb would you need on a mildly built 454?
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 12-15-2007, 06:58 AM   #18
webfoot
Re: 454 Swap???
I'd proably want at least an 850 on there.
-me
Old 12-15-2007, 07:12 AM   #19
smoky02
Re: 454 Swap???
Cool...guess I should start buying all the pieces i need...LOL
Old 12-15-2007, 07:27 AM   #20
webfoot
Re: 454 Swap???
Yeah, let me know when you're finished... all I have is a bare block and a plan!
Just too many projects around here...
-me
Old 12-15-2007, 10:35 AM   #21
stumpy
stumpy's Avatar
Re: 454 Swap???
What's the rush? Doing that has never worked out perfectly for me. I tend to find out after the fact that this doesn't always fit with that in every configuration.
BTW, anyone ever hear of C.A.T? http://www.catpep.com/default1.htm I like to save money but I'd rather not buy Chinese.
67 C10 LWB Fleet
Old 12-15-2007, 11:35 AM   #22
smoky02
Re: 454 Swap???
Well my truck is running and driving...so I'm gonna take my time...I don't even have a block yet...LOL
Old 12-15-2007, 11:55 AM   #23
496stroker1
Re: 454 Swap???
stumpy, probably stay away from CAT, check chevelles.com and search their forums for cat. there are alot of engine builders on that forum and they say quality is poor. scat is probly the best chinese stuff been around forever, used their crank and rods in 2 383 strokers and now a 496 been go so far.
Old 12-15-2007, 05:14 PM   #24
streetstar
streetstar's Avatar
Re: 454 Swap???
850 is pretty big, dude. A mild build would be served well by a 750 -- and even a 650 double pumper would suffice
Are you retired too?
Nonsense! I'm in my prime
streetstar is offline   Reply With Quote
Old 12-15-2007, 05:21 PM   #25
DieselEater
Re: 454 Swap???
My modified street pulling truck has 500HP and I use an 800 cfm Q-JET from JET industries......at 6500 RPM...
I'd slap a 750 Q-Jet on her and buy Cliff Ruggles book on them for tuning. BEST NON RACING CARB EVER BUILT!!!!!!!
As for your rotating assembly...unless you plan on spinning over 6500, you don't need anything else. Just put a good valve train, cam, intake and the jet and you could hit 400 HP easily.
A........
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
