crossmember swap-drop
in preperation formy next truck project i pulled the front crossmember from a 79 gmc. the project truck is a 67 short fleet and will be droped. i was thinking spindels and springs. then i got thinking some more, why not just open up the cross member and drop the frame into it? this lead to more thinking. moter mounts- easy fix. then theres the drag link and tie rods. i don't have the frame in the shop yet to get a look at how this would work out. my ?is has anyone done this and what problems does it present?
common sense isn't so common anymore |
A guy with a truck
Re: crossmember swap-drop
Check in the suspension forum. Many have done this- XXL and CaptKaos are two that come to mind...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
thank you gringoloco
Search for 'crossmember notch' or 'crossmember drop' & check out this thread . ..... http://67-72chevytrucks.com/vboard/s...ad.php?t=60649 ....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-14-2007 at 05:20 PM. |
thanks scoti i read the firs 8 pages so far i'm not looking to lay frame or nothing i'm just looking for a cheap way to get a couple inches without altering suspention geoetry
Happy to be here
![]() Join Date: Mar 2000
It can be done, but it requires a few mods other than the crossmember.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 12-14-2007 at 07:31 PM. |
It took more clearancing on mine than what XXL had to do on his (keep this in mind).
at first glance i thought it would be a cheap easy way to get a few inches, but it looks like it would be easier to z the frame
If you're looking for more than 1" ~ 1.5". . . ..... yes, it would be better to 'Z'.
can i drop the frame into the crossmember 1-1.5" without any stearing or other major isues
#11 | |
My truck (68 crossmember (EDIT: It's actually a 73-up crossmember after thinking about it a little longer), stock 68 manual steering box, stock 68 manual pitman arm, Moog brand tie-rods for 73-up, factory 71-72 drag-link, 73-up Bell-Tech drop spindles) would not allow a 1.5" drop w/o removing the majority of the 'outside' portion of the u-bolts that hold the lower a-arm in place. I had read the max was 1.5" so my plan was to be conservative & only go 1 3/8"...... but that wouldn't work w/o removing more material than what I felt was safe. I settled on 1 1/8"; but it still took some creativity to ensure that my steering linkage had 1/8" clearance for lock to lock.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-15-2007 at 07:35 PM. Reason: CRS Disease |
so your saying it's alot of work for only 1". i never had or lowered a truck. i'm planing on 2.5" spindels and think i want more. not sure what using drop springs will do to suspension and stearing geoimtry. i want it to ride and drive as good if not alot better than new
#13 |
I did this. Yes, it is ALOT of work for a little over an inch. If I were to do it over, I would strongly consider a z. If you section the crossmember, don't go more than 1.25. With this amount, you will still need to shave some of the lip of the crossmember so the inner tie rods dont hit it. Good luck with it. If you have any questions, just ask.
#14 | |
The reason I did the c.member section was simply to raise the lowest part of the front end.... the a-arm shafts (since they're the first things to hit). I just wanted the added 1"+ of clearance for safety margin. But, after cutting the crossmember, clearancing, assembling, plumbing, & painting the front suspension of the truck, I've stepped up my game & purchased a PorterBuilt-Streetrods 'Dropmember'. That gives me even more ground clearance if I keep air in the bags or it will go lower if I yank the inner wheelwells.
#15 |
A friend of mine did 4" using this method but he was making a entirely new frame so it made sense. I think the problem is that to retain steering to suspension alignmnet you have to raise all the steering components(steering box and idler arm) as well. If you start looking at it you see that you have to modify the frame in front of the crossmember for steering linkage clearence. I suppose that you could leave the steering stuff in the stock location but Id imagine bump steer could be a problem. By the way, my friend had to cut up the center link and put a dropped section into it to clear the engine oil pan.
